Saltar al contenido principal
Nokia 3120 SIM Card Replacement
Qué necesitas
  1. Nokia 3120 SIM Card Replacement, Battery Installation: paso 1, imagen 1 de 3 Nokia 3120 SIM Card Replacement, Battery Installation: paso 1, imagen 2 de 3 Nokia 3120 SIM Card Replacement, Battery Installation: paso 1, imagen 3 de 3
    • Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
  2. Nokia 3120 SIM Card Replacement: paso 2, imagen 1 de 1
    • Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out. This can be done with your finger-nail or a prying tool.
  3. Nokia 3120 SIM Card Replacement, SIM Card: paso 3, imagen 1 de 1
    • Once the battery is removed, the SIM card compartment will be exposed. Pry the compartment open as seen in the figure. This can be done using your fingernail or a prying mechanism.
  4. Nokia 3120 SIM Card Replacement: paso 4, imagen 1 de 1
    • Once the SIM card compartment has been opened, insert the SIM card into the slot provided on the left side.
Conclusión
3 personas más completaron esta guía.
Justin Emerson
Miembro Desde 03/11/13
166 Reputación
2 Guías creadas
Equipo
Clemson, Team 13-2, Benson Spring 2013 Miembro de Clemson, Team 13-2, Benson Spring 2013
CLEM-BENSON-S13S13G2
Miembros de 3
14 Guías creadas
Un comentario
Thanks , appreciated.
Ian McCully - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 15
Todo El Tiempo: 5,658
