Introducción
The SIM card is used to store information and it is well hidden under the battery. It is very easy to open once you know where it is.
Partes
No se requieren partes.
Remove the back cover plate of the phone.  To do this press down the lock as you slide the cover toward the bottom of the phone.
  • Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
Agregar Comentario
Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out.  This can be done with your finger-nail or a prying tool.
  • Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out. This can be done with your finger-nail or a prying tool.
Agregar Comentario
  • Once the battery is removed, the SIM card compartment will be exposed. Pry the compartment open as seen in the figure. This can be done using your fingernail or a prying mechanism.
Agregar Comentario
  • Once the SIM card compartment has been opened, insert the SIM card into the slot provided on the left side.
Agregar Comentario
Conclusión
3 personas más completaron esta guía.
Justin Emerson
Miembro Desde 11/03/13
148 Reputación
4 Guías creadas
Equipo
Clemson, Team 13-2, Benson Spring 2013 Miembro de Clemson, Team 13-2, Benson Spring 2013
CLEM-BENSON-S13S13G2
3 Miembros
14 Guías creadas
Thanks , appreciated.
Ian McCully - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 13
Últimos 30 Días: 56
Todo El Tiempo: 3,201
