Saltar al contenido principal
Nokia 2610 Keypad Replacement
Qué necesitas
  1. Nokia 2610 Keypad Replacement, Battery and Sim Card: paso 1, imagen 1 de 3 Nokia 2610 Keypad Replacement, Battery and Sim Card: paso 1, imagen 2 de 3 Nokia 2610 Keypad Replacement, Battery and Sim Card: paso 1, imagen 3 de 3
    • Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
  2. Nokia 2610 Keypad Replacement: paso 2, imagen 1 de 3 Nokia 2610 Keypad Replacement: paso 2, imagen 2 de 3 Nokia 2610 Keypad Replacement: paso 2, imagen 3 de 3
    • Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone.
  3. Nokia 2610 Keypad Replacement: paso 3, imagen 1 de 3 Nokia 2610 Keypad Replacement: paso 3, imagen 2 de 3 Nokia 2610 Keypad Replacement: paso 3, imagen 3 de 3
    • Lift the metal sim card holder (at the bottom of the battery slot) up and carefully pry the sim card out of its slot with a plastic opening tool or your finger.
    • After removal, lower the metal sim card holder into its original position.
  4. Nokia 2610 Keypad Replacement, Front Pannel: paso 4, imagen 1 de 2 Nokia 2610 Keypad Replacement, Front Pannel: paso 4, imagen 2 de 2
    • Insert the plastic opening tool into the crack between the front and back panels.
    • Gently pry the front cover away from the back cover while sliding the plastic opening tool towards the top of the phone.
  5. Nokia 2610 Keypad Replacement: paso 5, imagen 1 de 2 Nokia 2610 Keypad Replacement: paso 5, imagen 2 de 2
    • Lift the bottom of the front cover away from the phone.
    • Continue lifting until the top of the front cover is fully removed from the phone.
    • Note: To replace the Keypad, gently lift it out of the front cover. It is located below the clear viewing window.
  6. Nokia 2610 Keypad Replacement, Keypad: paso 6, imagen 1 de 2 Nokia 2610 Keypad Replacement, Keypad: paso 6, imagen 2 de 2
    • Push on the keypad from the exterior of the phone's front cover to separate the keypad from the phone.
Conclusión
Jeff Carter
Miembro Desde 10/05/10
94 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 7-52, Amido Fall 2010 Miembro de Cal Poly, Team 7-52, Amido Fall 2010
CPSU-AMIDO-F10S7G52
Miembros de 4
12 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 12
Todo El Tiempo: 2,053
