Saltar al contenido principal
Nokia 2610 Battery and Sim Card Replacement
Qué necesitas
  1. Nokia 2610 Battery and Sim Card Replacement, Battery and Sim Card: paso 1, imagen 1 de 3 Nokia 2610 Battery and Sim Card Replacement, Battery and Sim Card: paso 1, imagen 2 de 3 Nokia 2610 Battery and Sim Card Replacement, Battery and Sim Card: paso 1, imagen 3 de 3
    • Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
  2. Nokia 2610 Battery and Sim Card Replacement: paso 2, imagen 1 de 3 Nokia 2610 Battery and Sim Card Replacement: paso 2, imagen 2 de 3 Nokia 2610 Battery and Sim Card Replacement: paso 2, imagen 3 de 3
    • Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone.
  3. Nokia 2610 Battery and Sim Card Replacement: paso 3, imagen 1 de 3 Nokia 2610 Battery and Sim Card Replacement: paso 3, imagen 2 de 3 Nokia 2610 Battery and Sim Card Replacement: paso 3, imagen 3 de 3
    • Lift the metal sim card holder (at the bottom of the battery slot) up and carefully pry the sim card out of its slot with a plastic opening tool or your finger.
    • After removal, lower the metal sim card holder into its original position.
Conclusión
5 personas más completaron esta guía.
Equipo
Cal Poly, Team 7-52, Amido Fall 2010 Miembro de Cal Poly, Team 7-52, Amido Fall 2010
CPSU-AMIDO-F10S7G52
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 6,349
