Qué necesitas
Be sure cell phone is off before you begin to disassemble the phone.
Press the button on the bottom of the back of the cell phone.
Slide rear panel down and remove it.
Insert the plastic opening tool under the faceplate.
Separate the faceplate from main body by twisting the prying tool with some force.
The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
Locate and remove the six screws on the front of the phone using a T6 Torx.
All 6 screws are 6.9mm long.
With the motherboard and LCD unit removed, gently pull the power button out of its housing.
Flip phone over and find the sticker that holds the metallic plating together with the phone's case.
Pry off the portion of the sticker that is attached to the phone's case. Do not worry about removing the sticker from the metallic plate.
Una persona más ha completado esta guía.
