Saltar al contenido principal
Partes
No se especificaron partes.
  1. Be sure cell phone is off before you begin to disassemble the phone. Press the button on the bottom of the back of the cell phone. Slide rear panel down and remove  it.
    • Be sure cell phone is off before you begin to disassemble the phone.
    • Press the button on the bottom of the back of the cell phone.
    • Slide rear panel down and remove it.
  2. Using your fingernail, pry the back of the battery upwards and pull out. Using your fingernail, pry the back of the battery upwards and pull out. Using your fingernail, pry the back of the battery upwards and pull out.
    • Using your fingernail, pry the back of the battery upwards and pull out.
  3. Insert the plastic opening tool under the faceplate. Separate the faceplate from main body by twisting the prying tool with some force. The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
    • Insert the plastic opening tool under the faceplate.
    • Separate the faceplate from main body by twisting the prying tool with some force.
    • The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
  4. With the faceplate removed, simply peel off rubber key pad and remove. With the faceplate removed, simply peel off rubber key pad and remove. With the faceplate removed, simply peel off rubber key pad and remove.
    • With the faceplate removed, simply peel off rubber key pad and remove.
  5. Kits de Reparación de Batería de iPhone
    Sólo $29.99
    Buy Now
    Sólo $29.99
    Buy Now
  6. Locate and remove the six screws on the front of the phone using a T6 Torx. All 6 screws are 6.9mm long. All 6 screws are 6.9mm long.
    • Locate and remove the six screws on the front of the phone using a T6 Torx.
    • All 6 screws are 6.9mm long.
  7. After removing screws, lift the motherboard assembly straight off the cell phone body. After removing screws, lift the motherboard assembly straight off the cell phone body. After removing screws, lift the motherboard assembly straight off the cell phone body.
    • After removing screws, lift the motherboard assembly straight off the cell phone body.
  8. With the motherboard and LCD unit removed, gently pull the power button out of its housing. With the motherboard and LCD unit removed, gently pull the power button out of its housing. With the motherboard and LCD unit removed, gently pull the power button out of its housing.
    • With the motherboard and LCD unit removed, gently pull the power button out of its housing.
  9. Flip phone over and find the sticker that holds the metallic plating together with the phone's case. Pry off the portion of the sticker that is attached to the phone's case. Do not worry about removing the sticker from the metallic plate. Pry off the portion of the sticker that is attached to the phone's case. Do not worry about removing the sticker from the metallic plate.
    • Flip phone over and find the sticker that holds the metallic plating together with the phone's case.
    • Pry off the portion of the sticker that is attached to the phone's case. Do not worry about removing the sticker from the metallic plate.
  10. Locate the small hook that holds the metallic plate and phone case together on the front side of the phone Place your thumbs on the backside of the metallic plate. Stretch phone casing outward to detach hook from metallic plating. Simultaneously push metallic plate outward to remove.
    • Locate the small hook that holds the metallic plate and phone case together on the front side of the phone
    • Place your thumbs on the backside of the metallic plate.
    • Stretch phone casing outward to detach hook from metallic plating. Simultaneously push metallic plate outward to remove.
  11. Pry out the power unit once the metallic plate has been removed. Pry out the power unit once the metallic plate has been removed. Pry out the power unit once the metallic plate has been removed.
    • Pry out the power unit once the metallic plate has been removed.
  12. Be sure to place the power unit back into the phone's case with the gold hardware pointing upward.
    • Be sure to place the power unit back into the phone's case with the gold hardware pointing upward.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 20-8, Maness Fall 2010 Miembro de Cal Poly, Team 20-8, Maness Fall 2010
CPSU-MANESS-F10S20G8
4 Miembros
24 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 583
