Partes
No se requieren partes.
  1. Insert the plastic opening tool under the faceplate.
    • Insert the plastic opening tool under the faceplate.
    • Separate the faceplate from main body by twisting the prying tool with some force.
    • The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
    Agregar Comentario
  2. With the faceplate removed, simply peel off rubber key pad and remove.
    • With the faceplate removed, simply peel off rubber key pad and remove.
    Agregar Comentario
    • Locate and remove the six screws on the front of the phone using a T6 Torx.
      • All 6 screws are 6.9mm long.
    Agregar Comentario
    • After removing screws, lift the motherboard assembly straight off the cell phone body.
    Agregar Comentario
    • Be sure cell phone is off before you begin to disassemble the phone.
    • Press the button on the bottom of the back of the cell phone.
    • Slide rear panel down and remove it.
    Agregar Comentario
    • Using your fingernail, pry the back of the battery upwards and pull out.
    Agregar Comentario
    • With the LCD unit removed, gently press out the speaker with a non-metallic pointed object.
    Agregar Comentario
Conclusión
Equipo
Cal Poly, Team 20-8, Maness Fall 2010 Miembro de Cal Poly, Team 20-8, Maness Fall 2010
CPSU-MANESS-F10S20G8
4 Miembros
28 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 217
