Saltar al contenido principal
Nokia 2128i Internal Clock Battery Replacement
Qué necesitas
  1. Nokia 2128i Internal Clock Battery Replacement, Battery: paso 1, imagen 1 de 3 Nokia 2128i Internal Clock Battery Replacement, Battery: paso 1, imagen 2 de 3 Nokia 2128i Internal Clock Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Be sure cell phone is off before you begin to disassemble the phone.
    • Press the button on the bottom of the back of the cell phone.
    • Slide rear panel down and remove it.
  2. Nokia 2128i Internal Clock Battery Replacement: paso 2, imagen 1 de 3 Nokia 2128i Internal Clock Battery Replacement: paso 2, imagen 2 de 3 Nokia 2128i Internal Clock Battery Replacement: paso 2, imagen 3 de 3
    • Using your fingernail, pry the back of the battery upwards and pull out.
  3. Nokia 2128i Internal Clock Battery Replacement, Faceplate: paso 3, imagen 1 de 3 Nokia 2128i Internal Clock Battery Replacement, Faceplate: paso 3, imagen 2 de 3 Nokia 2128i Internal Clock Battery Replacement, Faceplate: paso 3, imagen 3 de 3
    • Insert the plastic opening tool under the faceplate.
    • Separate the faceplate from main body by twisting the prying tool with some force.
    • The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
  4. Nokia 2128i Internal Clock Battery Replacement, Keypad: paso 4, imagen 1 de 3 Nokia 2128i Internal Clock Battery Replacement, Keypad: paso 4, imagen 2 de 3 Nokia 2128i Internal Clock Battery Replacement, Keypad: paso 4, imagen 3 de 3
    • With the faceplate removed, simply peel off rubber key pad and remove.
  5. Nokia 2128i Internal Clock Battery Replacement, Motherboard Assembly: paso 5, imagen 1 de 3 Nokia 2128i Internal Clock Battery Replacement, Motherboard Assembly: paso 5, imagen 2 de 3 Nokia 2128i Internal Clock Battery Replacement, Motherboard Assembly: paso 5, imagen 3 de 3
    • Locate and remove the six screws on the front of the phone using a T6 Torx.
    • All 6 screws are 6.9mm long.
  6. Nokia 2128i Internal Clock Battery Replacement: paso 6, imagen 1 de 3 Nokia 2128i Internal Clock Battery Replacement: paso 6, imagen 2 de 3 Nokia 2128i Internal Clock Battery Replacement: paso 6, imagen 3 de 3
    • After removing screws, lift the motherboard assembly straight off the cell phone body.
  7. Nokia 2128i Internal Clock Battery Replacement, Internal Clock Battery: paso 7, imagen 1 de 2 Nokia 2128i Internal Clock Battery Replacement, Internal Clock Battery: paso 7, imagen 2 de 2
    • With the logic board completely removed, gently pry out the internal clock battery from its housing.
Conclusión
Una persona más ha completado esta guía.
Curtis Lutje
Miembro Desde 10/07/10
28 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 20-8, Maness Fall 2010 Miembro de Cal Poly, Team 20-8, Maness Fall 2010
CPSU-MANESS-F10S20G8
4 Miembros
24 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 3,363
