Saltar al contenido principal
Nokia 2115i Motherboard Replacement
Qué necesitas
  1. Nokia 2115i Motherboard Replacement, Nokia 2115i Battery: paso 1, imagen 1 de 3 Nokia 2115i Motherboard Replacement, Nokia 2115i Battery: paso 1, imagen 2 de 3 Nokia 2115i Motherboard Replacement, Nokia 2115i Battery: paso 1, imagen 3 de 3
    • To prevent shock, press down on the power button located on the top of the phone until the phone shuts off.
    • Press down on the small gray button located on the back of the phone.
    • Slide the back plate down and off.
  2. Nokia 2115i Motherboard Replacement: paso 2, imagen 1 de 2 Nokia 2115i Motherboard Replacement: paso 2, imagen 2 de 2
    • To remove the battery, begin by holding the phone sideways.
    • Then, insert your thumb in the groove below the battery and push the battery up and out.
  3. Nokia 2115i Motherboard Replacement, Faceplate: paso 3, imagen 1 de 3 Nokia 2115i Motherboard Replacement, Faceplate: paso 3, imagen 2 de 3 Nokia 2115i Motherboard Replacement, Faceplate: paso 3, imagen 3 de 3
    • Locate the spudger. A photo of the correct spudger is provided to the left.
    • Turn the front of the phone to face you. Find the two small square holes on the bottom left and right sides of the faceplate.
    • Insert the spudger into each square hole and push up to detach the face plate.
  4. Nokia 2115i Motherboard Replacement, Removing the Keypad: paso 4, imagen 1 de 2 Nokia 2115i Motherboard Replacement, Removing the Keypad: paso 4, imagen 2 de 2
    • Note: The keypad will be loose and may fall off during this step.
    • Pull the face plate up and off of the phone.
    • To remove the keypad, simply lift it off the phone.
  5. Nokia 2115i Motherboard Replacement, Removing the Motherboard: paso 5, imagen 1 de 2 Nokia 2115i Motherboard Replacement, Removing the Motherboard: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Locate the 6 screws on the metallic sheet that previously held the keypad. (This sheet, shown in the pictures, is the top side of the motherboard).
    • Note: 2 of the screws are on the bottom corners, 2 are on the right and left edges of the phone below the screen, and 2 are on the very top corners of the phone, above the screen.
    • Warning: The middle two screws are attached to the base of the phone with two black plastic rings. Use tweezers to remove the screws carefully to avoid breaking the plastic rings
    • Use a size T6 Torx screwdriver to remove each of these 6 screws.
  6. Nokia 2115i Motherboard Replacement: paso 6, imagen 1 de 3 Nokia 2115i Motherboard Replacement: paso 6, imagen 2 de 3 Nokia 2115i Motherboard Replacement: paso 6, imagen 3 de 3
    • To remove the motherboard, lift it up and off the phone.
    • Note: The screen will still be attached to the motherboard.
Conclusión
Shane
Miembro Desde 09/30/10
80 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 14-38, Forte Fall 2010 Miembro de Cal Poly, Team 14-38, Forte Fall 2010
CPSU-FORTE-F10S14G38
Miembros de 5
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 12
Todo El Tiempo: 2,973
