Saltar al contenido principal
Nokia 2115i Faceplate Replacement
Qué necesitas
  1. Nokia 2115i Faceplate Replacement, Nokia 2115i Battery: paso 1, imagen 1 de 3 Nokia 2115i Faceplate Replacement, Nokia 2115i Battery: paso 1, imagen 2 de 3 Nokia 2115i Faceplate Replacement, Nokia 2115i Battery: paso 1, imagen 3 de 3
    • To prevent shock, press down on the power button located on the top of the phone until the phone shuts off.
    • Press down on the small gray button located on the back of the phone.
    • Slide the back plate down and off.
  2. Nokia 2115i Faceplate Replacement: paso 2, imagen 1 de 2 Nokia 2115i Faceplate Replacement: paso 2, imagen 2 de 2
    • To remove the battery, begin by holding the phone sideways.
    • Then, insert your thumb in the groove below the battery and push the battery up and out.
  3. Nokia 2115i Faceplate Replacement, Faceplate: paso 3, imagen 1 de 3 Nokia 2115i Faceplate Replacement, Faceplate: paso 3, imagen 2 de 3 Nokia 2115i Faceplate Replacement, Faceplate: paso 3, imagen 3 de 3
    • Locate the spudger. A photo of the correct spudger is provided to the left.
    • Turn the front of the phone to face you. Find the two small square holes on the bottom left and right sides of the faceplate.
    • Insert the spudger into each square hole and push up to detach the face plate.
Conclusión
Shane
Miembro Desde 09/30/10
80 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 14-38, Forte Fall 2010 Miembro de Cal Poly, Team 14-38, Forte Fall 2010
CPSU-FORTE-F10S14G38
5 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,547
