Saltar al contenido principal
Nokia 1100b RH-36 Speaker Replacement
Qué necesitas
  1. Nokia 1100b RH-36 Speaker Replacement, Battery Cover: paso 1, imagen 1 de 2 Nokia 1100b RH-36 Speaker Replacement, Battery Cover: paso 1, imagen 2 de 2
    • Flip the phone over so that the screen faces down.
    • Press the gray button on the battery cover and slide it down off the back of the phone.
  2. Nokia 1100b RH-36 Speaker Replacement, Battery: paso 2, imagen 1 de 1
    • Wedge the flat end of the spudger into the small indent next to the Nokia logo on the battery.
    • Gently pry the battery out of the phone.
  3. Nokia 1100b RH-36 Speaker Replacement, Inner Casing: paso 3, imagen 1 de 2 Nokia 1100b RH-36 Speaker Replacement, Inner Casing: paso 3, imagen 2 de 2
    • Remove the six 6mm T6 Torx screws around the edge of the front of the phone.
    • Remove the metal frame holding the screen and speaker.
  4. Nokia 1100b RH-36 Speaker Replacement, Screen: paso 4, imagen 1 de 2 Nokia 1100b RH-36 Speaker Replacement, Screen: paso 4, imagen 2 de 2
    • Flip over the metal frame you just removed.
    • Using the flat end of the spudger, pry apart the inner clear plastic frame with screen attached from the metal frame.
    • Remove the screen bearing plastic frame.
  5. Nokia 1100b RH-36 Speaker Replacement, Speaker: paso 5, imagen 1 de 2 Nokia 1100b RH-36 Speaker Replacement, Speaker: paso 5, imagen 2 de 2
    • Gently remove the speaker from the top of the metal frame.
Conclusión
4 personas más completaron esta guía.
JSwan
Miembro Desde 04/12/13
781 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 10-43, Amido Spring 2013 Miembro de Cal Poly, Team 10-43, Amido Spring 2013
CPSU-AMIDO-S13S10G43
Miembros de 4
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 23
Todo El Tiempo: 2,062
