Saltar al contenido principal
Nokero SunRay Pro Power Panel USB Assembly Replacement
Qué necesitas
  1. Nokero SunRay Pro Power Panel USB Assembly Replacement, Front and Back Case: paso 1, imagen 1 de 1
    • Turn over the device so that the back of the device is facing up.
  2. Nokero SunRay Pro Power Panel USB Assembly Replacement: paso 2, imagen 1 de 3 Nokero SunRay Pro Power Panel USB Assembly Replacement: paso 2, imagen 2 de 3 Nokero SunRay Pro Power Panel USB Assembly Replacement: paso 2, imagen 3 de 3
    • Insert the first plastic opening tool along the side to pry open the case.
    • Sliding the plastic opening tool, while inserted, along the seam may help the removal process.
    • Use a second plastic opening tool to help separate the remaining seams.
  3. Nokero SunRay Pro Power Panel USB Assembly Replacement: paso 3, imagen 1 de 2 Nokero SunRay Pro Power Panel USB Assembly Replacement: paso 3, imagen 2 de 2
    • There is a long strip of double sided adhesive foam tape that prevents the back case from easily being removed.
    • Pull the back case off by applying steady pressure to remove it from the adhesive foam tape.
  4. Nokero SunRay Pro Power Panel USB Assembly Replacement: paso 4, imagen 1 de 2 Nokero SunRay Pro Power Panel USB Assembly Replacement: paso 4, imagen 2 de 2
    • Use the Phillips precision screwdriver to unscrew the two 5.0 mm Phillips screws from the circuit board.
    • Remove the solar panel and circuit board from the front case.
  5. Nokero SunRay Pro Power Panel USB Assembly Replacement, USB Assembly/ Solar Panel: paso 5, imagen 1 de 2 Nokero SunRay Pro Power Panel USB Assembly Replacement, USB Assembly/ Solar Panel: paso 5, imagen 2 de 2
    • Solder the two contact points identified by the "S+" and "S-" to disconnect the USB assembly.
Conclusión
Una persona más ha completado esta guía.
Nicholas Orr
Miembro Desde 01/20/15
229 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 9-3, Blackwell Winter 2015 Miembro de USF Tampa, Team 9-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G3
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 166
