Saltar al contenido principal
Nokero N400 Switch Replacement
Qué necesitas
  1. Nokero N400 Switch Replacement, Remove Battery Cover: paso 1, imagen 1 de 3 Nokero N400 Switch Replacement, Remove Battery Cover: paso 1, imagen 2 de 3 Nokero N400 Switch Replacement, Remove Battery Cover: paso 1, imagen 3 de 3
    • Press down firmly to remove the battery cover and display battery.
    • Then remove the battery.
  2. Nokero N400 Switch Replacement, Unscrew Back Cover: paso 2, imagen 1 de 2 Nokero N400 Switch Replacement, Unscrew Back Cover: paso 2, imagen 2 de 2
    • Remove the 7mm Phillips #1 screw.
  3. Nokero N400 Switch Replacement, Pry Open Back Cover: paso 3, imagen 1 de 2 Nokero N400 Switch Replacement, Pry Open Back Cover: paso 3, imagen 2 de 2
    • Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
    • Unlatch the clips on the inside and pull device apart.
    • Some clips will break when forced open.
  4. Nokero N400 Switch Replacement, Remove Switch From Housing: paso 4, imagen 1 de 1
    • Using a spudger carefully pry switch from housing.
  5. Nokero N400 Switch Replacement, Cut Old Switch Free: paso 5, imagen 1 de 1
    • Use wire cutters to cut the two black wires attached to the old switch.
    • You must use a splicer or a soldering gun to reattach the wires of the new switch.
    • If you splice the new switch wires together in the opposite order of the old switch wires, the new switch will still work.
Conclusión
Benjamin franklin
Miembro Desde 01/20/15
101 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 19-2, Blackwell Winter 2015 Miembro de USF Tampa, Team 19-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G2
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 128
