Saltar al contenido principal
Introducción
If the suction cup no longer sticks to surfaces or if the plastic has split, you will need to replace the suction cup with a new one.
  1. Press down firmly to remove the battery cover and display battery. Then remove the battery. Then remove the battery.
    • Press down firmly to remove the battery cover and display battery.
    • Then remove the battery.
  2. Remove the 7mm Phillips #1 screw. Remove the 7mm Phillips #1 screw.
    • Remove the 7mm Phillips #1 screw.
  3. Baterías para ordenadores portátiles
    Un pequeño arreglo para un gran resultado.
    Comprar Ahora
    Comprar Ahora
  4. Place the plastic opening tool in between the two plastic panels and slowly work your way around the device. Unlatch the clips on the inside and pull device apart.
    • Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
    • Unlatch the clips on the inside and pull device apart.
    • Some clips will break when forced open.
  5. Using tweezers, push the edges of the back end of the suction cup inward. Using tweezers, push the edges of the back end of the suction cup inward.
    • Using tweezers, push the edges of the back end of the suction cup inward.
  6. Flip the cover over and remove the suction cup by pulling at an angle. Be careful not to tear the plastic housing.
    • Flip the cover over and remove the suction cup by pulling at an angle.
    • Be careful not to tear the plastic housing.
    • During reassembly, make sure to press down uniformly on the suction cup for an even fit.
Conclusión
Daniel Bumiller
Miembro Desde 20/01/15
201 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 19-2, Blackwell Winter 2015 Miembro de USF Tampa, Team 19-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G2
4 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 1
Todo El Tiempo: 64
