Saltar al contenido principal
Nokero N400 Solar Panel Replacement
Qué necesitas
  1. Nokero N400 Solar Panel Replacement, Remove Battery Cover: paso 1, imagen 1 de 3 Nokero N400 Solar Panel Replacement, Remove Battery Cover: paso 1, imagen 2 de 3 Nokero N400 Solar Panel Replacement, Remove Battery Cover: paso 1, imagen 3 de 3
    • Press down firmly to remove the battery cover and display battery.
    • Then remove the battery.
  2. Nokero N400 Solar Panel Replacement, Unscrew Back Cover: paso 2, imagen 1 de 2 Nokero N400 Solar Panel Replacement, Unscrew Back Cover: paso 2, imagen 2 de 2
    • Remove the 7mm Phillips #1 screw.
  3. Nokero N400 Solar Panel Replacement, Pry Open Back Cover: paso 3, imagen 1 de 2 Nokero N400 Solar Panel Replacement, Pry Open Back Cover: paso 3, imagen 2 de 2
    • Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
    • Unlatch the clips on the inside and pull device apart.
    • Some clips will break when forced open.
  4. Nokero N400 Solar Panel Replacement, Solar Panel: paso 4, imagen 1 de 2 Nokero N400 Solar Panel Replacement, Solar Panel: paso 4, imagen 2 de 2
    • Pull the panel away from the rest of the assembly and cut the red and black wires coming from the panel
    • Be careful not to cut the ground-wire for the motherboard, it is the same color and goes to the exact same place as the solar panel wire.
    • For reassembly you will need to either splice, or solder the wires onto the replacement.
Conclusión
Daniel Bumiller
Miembro Desde 01/20/15
201 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 19-2, Blackwell Winter 2015 Miembro de USF Tampa, Team 19-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G2
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 133
