Saltar al contenido principal
Nokero N222-Huron O-Ring Replacement
Qué necesitas
  1. Nokero N222-Huron O-Ring Replacement, Clear Cover: paso 1, imagen 1 de 1
    • Grasp the clear cover and the white housing and twist the cover counter-clockwise.
    • The lid may hold fast, but it will come off with some firm twisting.
  2. Nokero N222-Huron O-Ring Replacement: paso 2, imagen 1 de 1
    • Lift the lid from the device
    • It may be helpful to use a spudger to pry under the lid if there is difficulty in getting a good grip on the smooth plastic.
  3. Nokero N222-Huron O-Ring Replacement, O-Ring: paso 3, imagen 1 de 3 Nokero N222-Huron O-Ring Replacement, O-Ring: paso 3, imagen 2 de 3 Nokero N222-Huron O-Ring Replacement, O-Ring: paso 3, imagen 3 de 3
    • Using a plastic spudger, lift the o-ring from the lid
  4. Nokero N222-Huron O-Ring Replacement: paso 4, imagen 1 de 1
    • Gently stretch the new O-ring and place it in position on the clear cover. Make sure it is flush with the flange and not interfering with the locking threads
Conclusión
Vinny Capone
Miembro Desde 10/18/13
549 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2013 Miembro de UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S2G4
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 7
Todo El Tiempo: 187
