Qué necesitas
the standard concrete drilled node
If your node is clamped or pole mounted skip to step 3
with the front tapcon removed you should be able to swing the node back toward the concrete surface it's mounted on
you'll likely need to loosen the back tapcon and pull up on the cantilever for the node to pivot freely
first, note if the pin is weight bearing. if so make sure to support the node while you remove the pin (or lock)
pull old node out
after sliding a new node in and replacing the pin or lock, measure the distance from the bottom of the ultrasonic depth sensor cone to the top of the cantilever beam. you may find a spare piece of strut to help with this.
you should do this before reattaching the front tapcon or clamp
if node is drilled into concrete swivel the cantilever back to its full extent and reattach the front tapcon
if the node is clamped, reclamp the node at its full extent
for a pole-mounted node, you should be able to swap without altering the structure at all
