Saltar al contenido principal
Nobis NB09 Battery Replacement
Qué necesitas
  1. Nobis NB09 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Before beginning this process, make sure the device is powered off.
    • Remove the screws holding the case together.
  2. Nobis NB09 Battery Replacement: paso 2, imagen 1 de 3 Nobis NB09 Battery Replacement: paso 2, imagen 2 de 3 Nobis NB09 Battery Replacement: paso 2, imagen 3 de 3
    • Use an opening tool to loosen and pry off the pink back plate.
  3. Nobis NB09 Battery Replacement: paso 3, imagen 1 de 2 Nobis NB09 Battery Replacement: paso 3, imagen 2 de 2
    • Remove the black electronic tape covering the circuit board.
  4. Nobis NB09 Battery Replacement: paso 4, imagen 1 de 1
    • Use the soldering iron to remove the black and red wires from the circuit board.
    • The black wire is the ground and the red wire is the battery positive terminal.
    • To reassemble, use the soldering iron to solder the leads at the end of the black (-) and red (+) wires from the new battery onto the proper terminals on the circuit board.
  5. Nobis NB09 Battery Replacement: paso 5, imagen 1 de 2 Nobis NB09 Battery Replacement: paso 5, imagen 2 de 2
    • Gently loosen the adhesive under the battery to avoid damaging it.
    • Use caution; the battery is soft and will bend very easily.
    • Dispose of the old battery properly at an electronic waste center or verified battery recycling store.
    • When reassembling, apply adhesive to the back of the new battery.
Conclusión
3 personas más completaron esta guía.
Jackson McAdams
Miembro Desde 04/01/15
390 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 7-1, Cichon Spring 2015 Miembro de UMass Dartmouth, Team 7-1, Cichon Spring 2015
UMASSD-CICHON-S15S7G1
4 Miembros
12 Guías creadas
Un comentario
where can i buy a battery from
Frederick Shipman - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 2,959
