Saltar al contenido principal
Introducción
You will be able to use this guide to successfully replace a faulty speaker on your tablet. To do so, you will need to disassemble your tablet and use soldering tools.
  1. Look towards the topside of the tablet, where the power button is located.
    • Look towards the topside of the tablet, where the power button is located.
    • Insert a plastic opening tool in the crack between the two parts of the case.
    • Move it gently back and forth to open the case.
  2. With the plastic opening tool in the opening between the two sides of the case, slide the tool along the tablet's border to separate the two sides completely. Be careful when you separate the two halves. Open the case from the opposite side of the camera, there is a cable connecting both halves of the case. Be careful when you separate the two halves. Open the case from the opposite side of the camera, there is a cable connecting both halves of the case.
    • With the plastic opening tool in the opening between the two sides of the case, slide the tool along the tablet's border to separate the two sides completely.
    • Be careful when you separate the two halves. Open the case from the opposite side of the camera, there is a cable connecting both halves of the case.
  3. Remove the tape holding the battery in place. Remove the tape holding the battery in place. Remove the tape holding the battery in place.
    • Remove the tape holding the battery in place.
  4. Insert the flat end of the spudger tool  in the crack beneath the battery. Move the spudger tool carefully side to side to remove the glue that is holding the battery in place. This is a soft battery, so a little bending is expected.
    • Insert the flat end of the spudger tool in the crack beneath the battery.
    • Move the spudger tool carefully side to side to remove the glue that is holding the battery in place.
    • This is a soft battery, so a little bending is expected.
  5. After the battery is unglued, locate the cables that connect it to the motherboard.
    • After the battery is unglued, locate the cables that connect it to the motherboard.
    • Annotate where each color goes to make the reassembly easier.
  6. Desolder the cables with a soldering iron and use a desoldering braid to remove the solder. Review the Ifixit soldering guide if you need help soldering.
    • Desolder the cables with a soldering iron and use a desoldering braid to remove the solder.
    • Review the Ifixit soldering guide if you need help soldering.
    • You can now remove the battery.
  7. Remove the tape holding the speaker in its socket. Remove the tape holding the speaker in its socket. Remove the tape holding the speaker in its socket.
    • Remove the tape holding the speaker in its socket.
  8. After you remove the tape, remove the speaker from its socket. You can place the speaker on one side of the tablet to have more freedom. Look for the place where the speaker's cables meet with the motherboard.
    • After you remove the tape, remove the speaker from its socket. You can place the speaker on one side of the tablet to have more freedom.
    • Look for the place where the speaker's cables meet with the motherboard.
    • Annotate where which color goes to make the reassembly easier.
  9. Use a soldering iron to desolder the cables and extract the solder using a desoldering braid. Review the Ifixit soldering guide if you need help soldering.
    • Use a soldering iron to desolder the cables and extract the solder using a desoldering braid.
    • You can now remove the speaker.
Conclusión
Daniel Gomero
Miembro Desde 21/01/15
930 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 5-5, Brown Winter 2015 Miembro de USF Tampa, Team 5-5, Brown Winter 2015
USFT-BROWN-W15S5G5
3 Miembros
10 Guías creadas
How can I restore the memory on these tablets - were having problems with this tablet please help us
annievvtait07 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 135
