Saltar al contenido principal
Nobis NB07 Cameras Replacement
Qué necesitas
  1. Nobis NB07 Cameras Replacement, Opening the case: paso 1, imagen 1 de 1
    • Look towards the topside of the tablet, where the power button is located.
    • Insert a plastic opening tool in the crack between the two parts of the case.
    • Move it gently back and forth to open the case.
  2. Nobis NB07 Cameras Replacement: paso 2, imagen 1 de 3 Nobis NB07 Cameras Replacement: paso 2, imagen 2 de 3 Nobis NB07 Cameras Replacement: paso 2, imagen 3 de 3
    • With the plastic opening tool in the opening between the two sides of the case, slide the tool along the tablet's border to separate the two sides completely.
    • Be careful when you separate the two halves. Open the case from the opposite side of the camera, there is a cable connecting both halves of the case.
  3. Nobis NB07 Cameras Replacement, Replacing the battery: paso 3, imagen 1 de 3 Nobis NB07 Cameras Replacement, Replacing the battery: paso 3, imagen 2 de 3 Nobis NB07 Cameras Replacement, Replacing the battery: paso 3, imagen 3 de 3
    • Remove the tape holding the battery in place.
  4. Nobis NB07 Cameras Replacement: paso 4, imagen 1 de 3 Nobis NB07 Cameras Replacement: paso 4, imagen 2 de 3 Nobis NB07 Cameras Replacement: paso 4, imagen 3 de 3
    • Insert the flat end of the spudger tool in the crack beneath the battery.
    • Move the spudger tool carefully side to side to remove the glue that is holding the battery in place.
    • This is a soft battery, so a little bending is expected.
  5. Nobis NB07 Cameras Replacement: paso 5, imagen 1 de 1
    • After the battery is unglued, locate the cables that connect it to the motherboard.
    • Annotate where each color goes to make the reassembly easier.
  6. Nobis NB07 Cameras Replacement: paso 6, imagen 1 de 2 Nobis NB07 Cameras Replacement: paso 6, imagen 2 de 2
    • Desolder the cables with a soldering iron and use a desoldering braid to remove the solder.
    • Review the Ifixit soldering guide if you need help soldering.
    • You can now remove the battery.
  7. Nobis NB07 Cameras Replacement, Removing the cameras: paso 7, imagen 1 de 3 Nobis NB07 Cameras Replacement, Removing the cameras: paso 7, imagen 2 de 3 Nobis NB07 Cameras Replacement, Removing the cameras: paso 7, imagen 3 de 3
    • Remove the black tape covering the cameras power cable.
  8. Nobis NB07 Cameras Replacement: paso 8, imagen 1 de 2 Nobis NB07 Cameras Replacement: paso 8, imagen 2 de 2
    • Use the spudger tool to pry upwards the ZIF connector and release the power cable.
  9. Nobis NB07 Cameras Replacement: paso 9, imagen 1 de 3 Nobis NB07 Cameras Replacement: paso 9, imagen 2 de 3 Nobis NB07 Cameras Replacement: paso 9, imagen 3 de 3
    Herramienta utilizada en este paso:
    • With the power cable disconnected, the backside camera is free. However, both cameras are sequentially connected through the power cable; the front side camera is glued to the motherboard.
    • Using tweezers, carefully grab the front camera and twist slowly.
    • The camera should release easily, do not twist too hard.
    • You can now remove the cameras.
Conclusión
Daniel Gomero
Miembro Desde 01/21/15
966 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 5-5, Brown Winter 2015 Miembro de USF Tampa, Team 5-5, Brown Winter 2015
USFT-BROWN-W15S5G5
Miembros de 3
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 150
