Saltar al contenido principal
Nite Ize Inova Microlight Casing Replacement
Qué necesitas
  1. Nite Ize Inova Microlight Casing Replacement, Case Removal: paso 1, imagen 1 de 2 Nite Ize Inova Microlight Casing Replacement, Case Removal: paso 1, imagen 2 de 2
    • Insert the plastic opening tool into the seam of the device.
  2. Nite Ize Inova Microlight Casing Replacement, Battery Removal: paso 2, imagen 1 de 3 Nite Ize Inova Microlight Casing Replacement, Battery Removal: paso 2, imagen 2 de 3 Nite Ize Inova Microlight Casing Replacement, Battery Removal: paso 2, imagen 3 de 3
    • Squeeze the top battery using a tweezer and pull the battery away from the light bulb.
    • Repeat this step for the bottom remaining battery.
    • Do not pull up on the battery as this will bend the metal contact.
  3. Nite Ize Inova Microlight Casing Replacement, LED Light Removal: paso 3, imagen 1 de 3 Nite Ize Inova Microlight Casing Replacement, LED Light Removal: paso 3, imagen 2 de 3 Nite Ize Inova Microlight Casing Replacement, LED Light Removal: paso 3, imagen 3 de 3
    • Place the plastic opening tool below the LED lamp and push away from the device until you hear a click.
    • Continue to remove the LED lamp the with your fingers.
  4. Nite Ize Inova Microlight Casing Replacement, Logic Board Removal: paso 4, imagen 1 de 1
    • Place the plastic opening tool behind the logic board and bend away from the casing
  5. Nite Ize Inova Microlight Casing Replacement, Logic Board Removal: paso 5, imagen 1 de 1
    • The logic board will pop out with ease.
Conclusión
Una persona más ha completado esta guía.
Equipo
CSU Fullerton, Team 2-1, Bruce Fall 2014 Miembro de CSU Fullerton, Team 2-1, Bruce Fall 2014
CSUF-BRUCE-F14S2G1
3 Miembros
3 Guías creadas
Un comentario
Great Job! found this one night while looking at my little blue light. Great tools, photos. +30
4-16-2017
F3ND1MUS - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 808
