Saltar al contenido principal
Nite Ize Inova Microlight Battery Replacement
Qué necesitas
  1. Nite Ize Inova Microlight Battery Replacement, Case Removal: paso 1, imagen 1 de 2 Nite Ize Inova Microlight Battery Replacement, Case Removal: paso 1, imagen 2 de 2
    • Insert the plastic opening tool into the seam of the device.
  2. Nite Ize Inova Microlight Battery Replacement, Battery Removal: paso 2, imagen 1 de 3 Nite Ize Inova Microlight Battery Replacement, Battery Removal: paso 2, imagen 2 de 3 Nite Ize Inova Microlight Battery Replacement, Battery Removal: paso 2, imagen 3 de 3
    • Squeeze the top battery using a tweezer and pull the battery away from the light bulb.
    • Repeat this step for the bottom remaining battery.
    • Do not pull up on the battery as this will bend the metal contact.
Conclusión
4 personas más completaron esta guía.
Equipo
CSU Fullerton, Team 2-1, Bruce Fall 2014 Miembro de CSU Fullerton, Team 2-1, Bruce Fall 2014
CSUF-BRUCE-F14S2G1
3 Miembros
3 Guías creadas
Un comentario
There is another Inova flashlight design that involves removing two Phillips type screw heads that are VERY TINY. I am able to unscrew one, but not the other, so am stuck and unable to replace the batteries.
Chrystin - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 52
Todo El Tiempo: 5,614
