Saltar al contenido principal
Nissan Versa Note Media Display System Replacement
Qué necesitas
  1. Nissan Versa Note Media Display System Replacement, Media Display System: paso 1, imagen 1 de 1
    • Ensure that the car is turned off.
  2. Nissan Versa Note Media Display System Replacement: paso 2, imagen 1 de 1
    • Pull on the switch for indoor/outdoor air to remove it.
  3. Nissan Versa Note Media Display System Replacement: paso 3, imagen 1 de 2 Nissan Versa Note Media Display System Replacement: paso 3, imagen 2 de 2
    • Use a spudger (or an old credit card) to gently pry the front panel away from the rest of the dash.
    • After wedging the parts apart you will see a gap.
  4. Nissan Versa Note Media Display System Replacement: paso 4, imagen 1 de 3 Nissan Versa Note Media Display System Replacement: paso 4, imagen 2 de 3 Nissan Versa Note Media Display System Replacement: paso 4, imagen 3 de 3
    • Using your fingers, start from the top of the panel and move down on either side to pry the panel open.
  5. Nissan Versa Note Media Display System Replacement: paso 5, imagen 1 de 2 Nissan Versa Note Media Display System Replacement: paso 5, imagen 2 de 2
    • Once the panel is free from the dash, flip it over to expose the cables connected to it.
  6. Nissan Versa Note Media Display System Replacement: paso 6, imagen 1 de 3 Nissan Versa Note Media Display System Replacement: paso 6, imagen 2 de 3 Nissan Versa Note Media Display System Replacement: paso 6, imagen 3 de 3
    • Remove the top cable by simply squeezing the end and pulling it out of its socket.
    • Use a spudger to push down on the tab of the bottom cable and remove it.
  7. Nissan Versa Note Media Display System Replacement: paso 7, imagen 1 de 3 Nissan Versa Note Media Display System Replacement: paso 7, imagen 2 de 3 Nissan Versa Note Media Display System Replacement: paso 7, imagen 3 de 3
    • The front panel is now completely free from the dash and can be set aside.
    • Using a Phillips #3 screwdriver, remove the two screws on either side of the media system.
  8. Nissan Versa Note Media Display System Replacement: paso 8, imagen 1 de 2 Nissan Versa Note Media Display System Replacement: paso 8, imagen 2 de 2
    • Carefully pull out the media system and turn it over so that the cables on its rear are visible.
    • Use your hands to pinch the tabs and gently pull out each cable.
  9. Nissan Versa Note Media Display System Replacement: paso 9, imagen 1 de 3 Nissan Versa Note Media Display System Replacement: paso 9, imagen 2 de 3 Nissan Versa Note Media Display System Replacement: paso 9, imagen 3 de 3
    • Now the media system is completely free from the car.
    • Using a T10 Torx screwdriver, unscrew the four screws on either side of the media system.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 19
Ultimos 30 días: 89
Todo El Tiempo: 3,496
