Introducción
In this guide, I will demonstrate how to fix a faulty power window switch on a 2005 Nissan Frontier (King Cab). I did this after the driver-side switch for controlling the passenger window did not work. After further inspection of the switch circuit board, I noticed that the electrical contacts were dirty. After the electrical contacts and reinstalling, the windows worked again.
Qué necesitas
Insert the first trim tool on the right side of the button molding.
Insert the second trim tool on the left, and shimmy it open.
Once the power window switch assembly has been rebuilt, simply use steps 3 to 1 to help you reinstall the switches.
5 personas más completaron esta guía.
6 comentarios
Nice guide, I was able to fix a window and lock issue with a simple cleaning thanks to these well-done instructions. Thanks
very helpful. thank you
I cleaned my entire assembly and my window is still stuck in my door. Switches won't work. Any chance there's a fix for the regulator wiring? I know it isn't broken. My window works just not how it's supposed to. Somehow it's doing opposite day while pressing it to go up? Highly confused?
