Saltar al contenido principal
Qué necesitas
  1. Nintendo Wii U Wireless Module Replacement, Console Outer Case: paso 1, imagen 1 de 1
    • With the bottom of the console facing up, remove the following 6 screws hidden underneath the white square stickers:
    • Three 5.1mm Phillips #000 screws
    • Two 6.1mm Tri-wing Y0 screws
    • One 13.2mm Tri-wing Y1 screw
  2. Nintendo Wii U Wireless Module Replacement: paso 2, imagen 1 de 1
    • Rotate the console 180 degrees so that the exhaust vents are facing you.
    • Remove the two 7.1mm Phillips #00 screws.
  3. Nintendo Wii U Wireless Module Replacement: paso 3, imagen 1 de 2 Nintendo Wii U Wireless Module Replacement: paso 3, imagen 2 de 2
    • On the side opposite of the exhaust vents, slide the cover faceplate towards the back of the console and pull upwards to release it.
  4. Nintendo Wii U Wireless Module Replacement: paso 4, imagen 1 de 1
    • On the bottom of the console beneath the previously removed faceplate, remove the three 13.2mm Tri-wing Y1 screws.
  5. Nintendo Wii U Wireless Module Replacement: paso 5, imagen 1 de 3 Nintendo Wii U Wireless Module Replacement: paso 5, imagen 2 de 3 Nintendo Wii U Wireless Module Replacement: paso 5, imagen 3 de 3
    • On the back of the console, lift up and release the main top cover.
  6. Nintendo Wii U Wireless Module Replacement, Front Faceplate: paso 6, imagen 1 de 2 Nintendo Wii U Wireless Module Replacement, Front Faceplate: paso 6, imagen 2 de 2
    • Rotate the device so that the front plate is facing you.
    • On each side of the console, remove the 3.5mm Phillips #0 screw connecting the DVD drive to the faceplate.
  7. Nintendo Wii U Wireless Module Replacement: paso 7, imagen 1 de 1
    • Rotate the device so that the front plate is on the right side and the ribbon cable is visible.
    • The ribbon cable is connected to the system by a latch which holds in the blue tab. Flip this latch up to unlock it.
    • Lift up on the blue tab to release the ribbon cable.
  8. Nintendo Wii U Wireless Module Replacement: paso 8, imagen 1 de 1
    • Remove the front faceplate.
  9. Nintendo Wii U Wireless Module Replacement, DVD Drive: paso 9, imagen 1 de 1
    • On each side of the DVD drive, remove the two 4.6mm Phillips #0 mounting screws.
  10. Nintendo Wii U Wireless Module Replacement: paso 10, imagen 1 de 2 Nintendo Wii U Wireless Module Replacement: paso 10, imagen 2 de 2
    • Rotate the device so that the DVD slot is visible.
    • A ribbon cable is attached to the bottom right side of the DVD drive. The ribbon cable can rip if it isn't removed properly.
    • Lift the DVD drive out of the mount and turn over to the right so it lies like a book.
    • Use a spudger to release the ribbon cable.
  11. Nintendo Wii U Wireless Module Replacement: paso 11, imagen 1 de 1
    • Remove the CD drive.
  12. Nintendo Wii U Wireless Module Replacement, Motherboard: paso 12, imagen 1 de 3 Nintendo Wii U Wireless Module Replacement, Motherboard: paso 12, imagen 2 de 3 Nintendo Wii U Wireless Module Replacement, Motherboard: paso 12, imagen 3 de 3
    • Remove the black plastic shielding by unscrewing connecting screws with a Phillip's Head screwdriver.
    • You will have to carefully adjust the antenna cables out of the way in order to proceed comfortably.
  13. Nintendo Wii U Wireless Module Replacement: paso 13, imagen 1 de 3 Nintendo Wii U Wireless Module Replacement: paso 13, imagen 2 de 3 Nintendo Wii U Wireless Module Replacement: paso 13, imagen 3 de 3
    • The metal cap does not require unscrewing and should lift up with ease.
    • Unscrew all the screws that outline the perimeter of the board using a Phillips Head (PH1) screwdriver.
    • Remove the silver shielding plate once all screws are removed. Be careful when pulling it under the affixed antenna cables.
  14. Nintendo Wii U Wireless Module Replacement: paso 14, imagen 1 de 2 Nintendo Wii U Wireless Module Replacement: paso 14, imagen 2 de 2
    • At this point, the motherboard should easily separate from the lower tray.
  15. Nintendo Wii U Wireless Module Replacement, Wireless 5ghz Module: paso 15, imagen 1 de 3 Nintendo Wii U Wireless Module Replacement, Wireless 5ghz Module: paso 15, imagen 2 de 3 Nintendo Wii U Wireless Module Replacement, Wireless 5ghz Module: paso 15, imagen 3 de 3
    • Flip the motherboard over to view the underside where the Wii U's wireless modules are located. The Bluetooth module is circled in red.
    • This module is affixed with strong adhesive, so in order to remove it you will need to wiggle the module with slight force for a couple of minutes.
Conclusión
4 personas más completaron esta guía.
Emily Vasquez
Miembro Desde 24/02/16
812 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 1-2, Leahy Spring 2016 Miembro de USF Tampa, Team 1-2, Leahy Spring 2016
USFT-LEAHY-S16S1G2
3 Miembros
11 Guías creadas
14 comentarios
Where would be able to buy this replacement part? Anyone know?
Salvador Mora - Contestar
I found on aliexpress
Rodrigo Mafort -
I actually just bought a secondary Wii U just to be sure I don't get a cheap part, it was like $65 with a credit on eBay
Salvador Mora -
Which one of these is for the module for control pad?:
Broadcom BCM43237KMLG Wireless LAN module
Broadcom BCM43362KUB6 802.11n Wireless Module—the same one used in the Roku 2 XS
Broadcom BCM20702 Bluetooth 4.0
Dan - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 31
Ultimos 30 días: 193
Todo El Tiempo: 9,529
