Saltar al contenido principal
Nintendo Wii U Pro Controller ZL and ZR Button Replacement
Qué necesitas
  1. Nintendo Wii U Pro Controller ZL and ZR Button Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the controller over to reveal the battery cover.
    • Use the J000 screwdriver to remove the screw that secures the battery cover.
  2. Nintendo Wii U Pro Controller ZL and ZR Button Replacement: paso 2, imagen 1 de 2 Nintendo Wii U Pro Controller ZL and ZR Button Replacement: paso 2, imagen 2 de 2
    • Remove the battery from the controller by inserting the plastic spudger into the small gap on the bottom right of the battery.
    • Use the spudger as a lever to pry up and remove the battery from the compartment.
  3. Nintendo Wii U Pro Controller ZL and ZR Button Replacement, ZL and ZR Buttons: paso 3, imagen 1 de 1
    • Once the battery has been removed, we will remove the 4 screws in the battery compartment and then the 4 screws around the back of the case. These 8 screws use the Y0 bit. Each of these screws are 5.5 mm.
    • The four screws on the outside are extremely deep into the casing, and the holes are pretty small. You will need to use a 4 mm driver bit extension to reach these screws.
  4. Nintendo Wii U Pro Controller ZL and ZR Button Replacement: paso 4, imagen 1 de 1
    • Once all of the screws are removed, simply use one hand to hold the front panel in place and lift up on the back panel to remove it. Place the back panel so the insides are facing up towards you.
  5. Nintendo Wii U Pro Controller ZL and ZR Button Replacement: paso 5, imagen 1 de 2 Nintendo Wii U Pro Controller ZL and ZR Button Replacement: paso 5, imagen 2 de 2
    • Locate the two triggers (ZL and ZR) and pop them up and out by pressing on them from the outside.
Conclusión
Una persona más ha completado esta guía.
Jesse Burton
Miembro Desde 09/17/15
595 Reputación
3 Guías creadas
Equipo
IUPUI, Team 2-2, Harley Fall 2015 Miembro de IUPUI, Team 2-2, Harley Fall 2015
IUPUI-HARLEY-F15S2G2
Miembros de 4
15 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 51
Todo El Tiempo: 5,076
