Saltar al contenido principal
Nintendo Wii U Pro Controller D-Pad Replacement
Qué necesitas
  1. Nintendo Wii U Pro Controller D-Pad Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the controller over to reveal the battery cover.
    • Use the J000 screwdriver to remove the screw that secures the battery cover.
  2. Nintendo Wii U Pro Controller D-Pad Replacement: paso 2, imagen 1 de 2 Nintendo Wii U Pro Controller D-Pad Replacement: paso 2, imagen 2 de 2
    • Remove the battery from the controller by inserting the plastic spudger into the small gap on the bottom right of the battery.
    • Use the spudger as a lever to pry up and remove the battery from the compartment.
  3. Nintendo Wii U Pro Controller D-Pad Replacement, Joystick: paso 3, imagen 1 de 1
    • Remove the eight 5.5 mm Y0 screws.
  4. Nintendo Wii U Pro Controller D-Pad Replacement: paso 4, imagen 1 de 2 Nintendo Wii U Pro Controller D-Pad Replacement: paso 4, imagen 2 de 2
    • Now that you have removed all of the screws, carefully separate and remove the bottom half of the controller shell from the top half.
    • If you feel any resistance when pulling the shells apart, use a spudger to separate the left and right trigger contact assemblies from the bottom shell.
  5. Nintendo Wii U Pro Controller D-Pad Replacement: paso 5, imagen 1 de 1
    • Move the right trigger and sensor out of the way.
    • Remove the 4 mm JIS #0 screw.
  6. Nintendo Wii U Pro Controller D-Pad Replacement: paso 6, imagen 1 de 1
    • Move the left trigger and sensor out of the way.
  7. Nintendo Wii U Pro Controller D-Pad Replacement: paso 7, imagen 1 de 1
    • Remove the joysticks and motherboard from the controller’s shell.
  8. Nintendo Wii U Pro Controller D-Pad Replacement: paso 8, imagen 1 de 1
    • Carefully pull the rubber thumbsticks off of the electronic bearings to remove the joysticks.
  9. Nintendo Wii U Pro Controller D-Pad Replacement, D-Pad: paso 9, imagen 1 de 1
    • Locate the two 4 mm motherboard screws, shown circled in red, with the J0 screwdriver.
  10. Nintendo Wii U Pro Controller D-Pad Replacement: paso 10, imagen 1 de 1
    • Remove the motherboard and connected components. The rubber pad of the D-Pad is indicated in the image by the red arrow.
  11. Nintendo Wii U Pro Controller D-Pad Replacement: paso 11, imagen 1 de 1
    • Remove the rubber pad and D-Pad button. The D-Pad can be replaced by the new D-Pad or be cleaned to improve condition.
Conclusión
3 personas más completaron esta guía.
Jesse Burton
Miembro Desde 09/17/15
586 Reputación
3 Guías creadas
Equipo
IUPUI, Team 2-2, Harley Fall 2015 Miembro de IUPUI, Team 2-2, Harley Fall 2015
IUPUI-HARLEY-F15S2G2
4 Miembros
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 46
Todo El Tiempo: 4,414
