Saltar al contenido principal
Nintendo Wii U DVD Drive Replacement
Qué necesitas
  1. Nintendo Wii U DVD Drive Replacement, Console Outer Case: paso 1, imagen 1 de 1
    • With the bottom of the console facing up, remove the following 6 screws hidden underneath the white square stickers:
    • Three 5.1mm Phillips #000 screws
    • Two 6.1mm Tri-wing Y0 screws
    • One 13.2mm Tri-wing Y1 screw
  2. Nintendo Wii U DVD Drive Replacement: paso 2, imagen 1 de 1
    • Rotate the console 180 degrees so that the exhaust vents are facing you.
    • Remove the two 7.1mm Phillips #00 screws.
  3. Nintendo Wii U DVD Drive Replacement: paso 3, imagen 1 de 2 Nintendo Wii U DVD Drive Replacement: paso 3, imagen 2 de 2
    • On the side opposite of the exhaust vents, slide the cover faceplate towards the back of the console and pull upwards to release it.
  4. Nintendo Wii U DVD Drive Replacement: paso 4, imagen 1 de 1
    • On the bottom of the console beneath the previously removed faceplate, remove the three 13.2mm Tri-wing Y1 screws.
  5. Nintendo Wii U DVD Drive Replacement: paso 5, imagen 1 de 3 Nintendo Wii U DVD Drive Replacement: paso 5, imagen 2 de 3 Nintendo Wii U DVD Drive Replacement: paso 5, imagen 3 de 3
    • On the back of the console, lift up and release the main top cover.
  6. Nintendo Wii U DVD Drive Replacement, Front Faceplate: paso 6, imagen 1 de 2 Nintendo Wii U DVD Drive Replacement, Front Faceplate: paso 6, imagen 2 de 2
    • Rotate the device so that the front plate is facing you.
    • On each side of the console, remove the 3.5mm Phillips #0 screw connecting the DVD drive to the faceplate.
  7. Nintendo Wii U DVD Drive Replacement: paso 7, imagen 1 de 1
    • Rotate the device so that the front plate is on the right side and the ribbon cable is visible.
    • The ribbon cable is connected to the system by a latch which holds in the blue tab. Flip this latch up to unlock it.
    • Lift up on the blue tab to release the ribbon cable.
  8. Nintendo Wii U DVD Drive Replacement: paso 8, imagen 1 de 1
    • Remove the front faceplate.
  9. Nintendo Wii U DVD Drive Replacement, DVD Drive: paso 9, imagen 1 de 1
    • On each side of the DVD drive, remove the two 4.6mm Phillips #0 mounting screws.
  10. Nintendo Wii U DVD Drive Replacement: paso 10, imagen 1 de 2 Nintendo Wii U DVD Drive Replacement: paso 10, imagen 2 de 2
    • Rotate the device so that the DVD slot is visible.
    • A ribbon cable is attached to the bottom right side of the DVD drive. The ribbon cable can rip if it isn't removed properly.
    • Lift the DVD drive out of the mount and turn over to the right so it lies like a book.
    • Use a spudger to release the ribbon cable.
  11. Nintendo Wii U DVD Drive Replacement: paso 11, imagen 1 de 1
    • Remove the CD drive.
Conclusión
50 personas más completaron esta guía.
Kim Arre
Miembro Desde 01/11/13
4,484 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 17-20, Forte Winter 2013 Miembro de Cal Poly, Team 17-20, Forte Winter 2013
CPSU-FORTE-W13S17G20
5 Miembros
28 Guías creadas
47 comentarios
I've done with twice with two different drives ordered on Ebay, and keep getting the same error code (160-1402). Is the place I'm buying from selling bad drives, or is there something else that needs to be done after? It goes back to working when I put my old one back in, so I know I'm physically doing it correctly.
Brad Senatore - Contestar
Update : For anybody else having this problem, you have to change out the logic board from your old drive to the new one. Pain in the neck, but works!
Brad Senatore -
What do you mean by change out the logic board?
gingindua -
the logic board is inside the disk drive. Remove it and replace it into the new disk drive. This is the same on the Xbox and Playstation
rehrnsberger -
Did an update it failed rebooted and now get a 160-1402. With the DVD drive cover off the Spindle isnt moving. Suspect Drive would seem 160-XXXX is DVD Drive related Errors
Ben Uwins - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 23
Ultimos 7 días: 121
Ultimos 30 días: 521
Todo El Tiempo: 71,919
