Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Introducción
Use this guide to remove the outer case of the Nintendo Wii U and gain access to the DVD drive.
  1. With the bottom of the console facing up, remove the following 6 screws hidden underneath the white square stickers:
    • With the bottom of the console facing up, remove the following 6 screws hidden underneath the white square stickers:
    • Three 5.1mm Phillips #000 screws
    • Two 6.1mm Tri-wing Y0 screws
    • One 13.2mm Tri-wing Y1 screw
  2. Rotate the console 180 degrees so that the exhaust vents are facing you.
    • Rotate the console 180 degrees so that the exhaust vents are facing you.
    • Remove the two 7.1mm Phillips #00 screws.
  3. Kits para Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. On the side opposite of the exhaust vents, slide the cover faceplate towards the back of the console and pull upwards to release it. On the side opposite of the exhaust vents, slide the cover faceplate towards the back of the console and pull upwards to release it.
    • On the side opposite of the exhaust vents, slide the cover faceplate towards the back of the console and pull upwards to release it.
  5. On the bottom of the console beneath the previously removed faceplate, remove the three 13.2mm Tri-wing Y1 screws.
    • On the bottom of the console beneath the previously removed faceplate, remove the three 13.2mm Tri-wing Y1 screws.
  6. On the back of the console, lift up and release the main top cover. On the back of the console, lift up and release the main top cover. On the back of the console, lift up and release the main top cover.
    • On the back of the console, lift up and release the main top cover.
Conclusión
17 personas más completaron esta guía.
Kim Arre
Miembro Desde 11/01/13
3,524 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 17-20, Forte Winter 2013 Miembro de Cal Poly, Team 17-20, Forte Winter 2013
CPSU-FORTE-W13S17G20
5 Miembros
19 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 45
Ultimos 30 días: 172
Todo El Tiempo: 18,588
