Saltar al contenido principal
Nintendo Wii U Button Replacement
Qué necesitas
  1. Nintendo Wii U Button Replacement, Button Replacement: paso 1, imagen 1 de 2 Nintendo Wii U Button Replacement, Button Replacement: paso 1, imagen 2 de 2
    • You will first need to find all the screws hidden underneath the black (or white) square stickers. They are all located on the bottom side of the Wii U.
    • Use a spudger to remove the stickers if it is difficult to peel off with your fingers.
  2. Nintendo Wii U Button Replacement: paso 2, imagen 1 de 1
    • Remove the five Phillips #0 screws.
    • Remove the four Tri-Wing Y1 screws.
  3. Nintendo Wii U Button Replacement: paso 3, imagen 1 de 2 Nintendo Wii U Button Replacement: paso 3, imagen 2 de 2
    • Remove the CMOS battery door on the left side of the console.
    • Once the door is removed, remove the three Phillips #0 screws.
  4. Nintendo Wii U Button Replacement: paso 4, imagen 1 de 3 Nintendo Wii U Button Replacement: paso 4, imagen 2 de 3 Nintendo Wii U Button Replacement: paso 4, imagen 3 de 3
    • Gently pry off the top lid of the Wii U.
  5. Nintendo Wii U Button Replacement: paso 5, imagen 1 de 3 Nintendo Wii U Button Replacement: paso 5, imagen 2 de 3 Nintendo Wii U Button Replacement: paso 5, imagen 3 de 3
    • Rotate the device so that the front plate is facing you.
    • Remove the two Phillips #1 screws.
  6. Nintendo Wii U Button Replacement: paso 6, imagen 1 de 3 Nintendo Wii U Button Replacement: paso 6, imagen 2 de 3 Nintendo Wii U Button Replacement: paso 6, imagen 3 de 3
    • Remove the ribbon cable and separate the front plate from the main console.
  7. Nintendo Wii U Button Replacement: paso 7, imagen 1 de 1
    • Remove the three Phillips #1 screws.
  8. Nintendo Wii U Button Replacement: paso 8, imagen 1 de 1
    • Once unscrewed, remove the black braces that hold the power button, eject button, and sync button in place.
  9. Nintendo Wii U Button Replacement: paso 9, imagen 1 de 1
    • Remove the desired button(s).
Conclusión
Emily Vasquez
Miembro Desde 02/24/16
812 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 1-2, Leahy Spring 2016 Miembro de USF Tampa, Team 1-2, Leahy Spring 2016
USFT-LEAHY-S16S1G2
3 Miembros
11 Guías creadas
Un comentario
Anyone know what that ribbon cable is in step 6? Just regular 9 pin?
Lugi - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 29
Ultimos 30 días: 104
Todo El Tiempo: 3,568
