Saltar al contenido principal
Nintendo Wii Remote Motherboard Replacement
Qué necesitas
  1. Nintendo Wii Remote Motherboard Replacement, Front Cover Plate and Batteries: paso 1, imagen 1 de 2 Nintendo Wii Remote Motherboard Replacement, Front Cover Plate and Batteries: paso 1, imagen 2 de 2
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
  2. Nintendo Wii Remote Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
  3. Nintendo Wii Remote Motherboard Replacement: paso 3, imagen 1 de 1
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
  4. Nintendo Wii Remote Motherboard Replacement: paso 4, imagen 1 de 2 Nintendo Wii Remote Motherboard Replacement: paso 4, imagen 2 de 2
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
  5. Nintendo Wii Remote Motherboard Replacement, Motherboard: paso 5, imagen 1 de 2 Nintendo Wii Remote Motherboard Replacement, Motherboard: paso 5, imagen 2 de 2
    • Using the connector port, gently lift the motherboard about 2 cm from the base.
    • Electrostatic discharge may damage the device. Be careful and avoid touching the electronic components as much as possible.
  6. Nintendo Wii Remote Motherboard Replacement: paso 6, imagen 1 de 2 Nintendo Wii Remote Motherboard Replacement: paso 6, imagen 2 de 2
    • Grasp the edges of the motherboard and pull it straight away from the case.
Conclusión
21 personas más completaron esta guía.
Emily
Miembro Desde 04/14/13
1,218 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 3-44, Amido Spring 2013 Miembro de Cal Poly, Team 3-44, Amido Spring 2013
CPSU-AMIDO-S13S3G44
4 Miembros
21 Guías creadas
6 comentarios
Where do you find a motherboard and how much do they typically cost?
Jeff - Contestar
This is useless because you can't just buy a motherboard. May as well buy a new remote for $20
Lisa Cole - Contestar
Where can i buy a brand new and original (not fake of course) wii remote for $20?
arttitudesign -
You can buy a first party Wii remote plus for under $50 at Walmart, best buy, or online on Amazon or on Nintendos website
Darren Woloshyn - Contestar
What is the dimension is the motherboard? I want to make a custom motherboard for the housing but I haven't managed to get int the wiimote yet as I am waiting for my tri screwdriver
Michael baldwin - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 56
Ultimos 30 días: 264
Todo El Tiempo: 27,756
