Saltar al contenido principal
Nintendo Wii Remote Main Buttons Replacement
Qué necesitas
  1. Nintendo Wii Remote Main Buttons Replacement, Front Cover Plate and Batteries: paso 1, imagen 1 de 2 Nintendo Wii Remote Main Buttons Replacement, Front Cover Plate and Batteries: paso 1, imagen 2 de 2
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
  2. Nintendo Wii Remote Main Buttons Replacement: paso 2, imagen 1 de 1
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
  3. Nintendo Wii Remote Main Buttons Replacement: paso 3, imagen 1 de 1
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
  4. Nintendo Wii Remote Main Buttons Replacement: paso 4, imagen 1 de 2 Nintendo Wii Remote Main Buttons Replacement: paso 4, imagen 2 de 2
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
  5. Nintendo Wii Remote Main Buttons Replacement, Main Buttons: paso 5, imagen 1 de 2 Nintendo Wii Remote Main Buttons Replacement, Main Buttons: paso 5, imagen 2 de 2
    • Working on the inside of the front cover, peel off the three rubber pads covering the buttons.
  6. Nintendo Wii Remote Main Buttons Replacement: paso 6, imagen 1 de 1
    • Flip over the cover, allowing the buttons to fall into your hand.
    • Be ready to catch all the buttons, some are very small. If a button does not fall out apply gentle pressure from behind.
    • When reassembling, put each plastic button in its allocated slot. Each button only fits snugly in one slot.
    • The best option for you is rotate the Wii Controller by 180°. If you obey this note, the small parts wont fall off and then you can remove the buttons.
Conclusión
16 personas más completaron esta guía.
Emily
Miembro Desde 04/14/13
1,218 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 3-44, Amido Spring 2013 Miembro de Cal Poly, Team 3-44, Amido Spring 2013
CPSU-AMIDO-S13S3G44
4 Miembros
21 Guías creadas
2 comentarios
Where did you get your replacement buttons? I can't find them online anywhere...
devannedloss - Contestar
Me too, can’t find them.
Michael Velten -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 20
Ultimos 7 días: 122
Ultimos 30 días: 587
Todo El Tiempo: 31,403
