Saltar al contenido principal
Nintendo Wii Fan Replacement
Qué necesitas
  1. Nintendo Wii Fan Replacement, Faceplate: paso 1, imagen 1 de 2 Nintendo Wii Fan Replacement, Faceplate: paso 1, imagen 2 de 2
    • Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
  2. Nintendo Wii Fan Replacement: paso 2, imagen 1 de 1
    • Remove the two 8.3 mm Tri-Point screws hidden under the covers you just removed.
  3. Nintendo Wii Fan Replacement: paso 3, imagen 1 de 1
    • Remove the single 5.9 mm Phillips screw under the controller port door nearest the faceplate.
  4. Nintendo Wii Fan Replacement: paso 4, imagen 1 de 1
    • Use a metal spudger to remove the rubber foot stuck to the side of the Wii near the DVD drive opening.
  5. Nintendo Wii Fan Replacement: paso 5, imagen 1 de 1
    • Remove the single 5.9 mm Phillips screw hidden under the foot you just removed.
  6. Nintendo Wii Fan Replacement: paso 6, imagen 1 de 2 Nintendo Wii Fan Replacement: paso 6, imagen 2 de 2
    • Carefully pull the faceplate away from the front of the Wii.
    • Use a pair of tweezers to disconnect the LED cable's plastic connector from the motherboard.
    • Remove the faceplate.
  7. Nintendo Wii Fan Replacement, Outer Case: paso 7, imagen 1 de 3 Nintendo Wii Fan Replacement, Outer Case: paso 7, imagen 2 de 3 Nintendo Wii Fan Replacement, Outer Case: paso 7, imagen 3 de 3
    • Open the controller port cover until it is perpendicular to the black controller port bezel.
    • Pull the controller port cover straight up to release it from the outer case.
    • Repeat this procedure for the memory card port cover.
  8. Nintendo Wii Fan Replacement: paso 8, imagen 1 de 2 Nintendo Wii Fan Replacement: paso 8, imagen 2 de 2
    • Remove the two remaining 4.1 mm Phillips screws along the top edge of the black plastic controller port bezel.
    • Lift the bezel from the long edge furthest away from the controller ports and remove it from the Wii.
  9. Nintendo Wii Fan Replacement: paso 9, imagen 1 de 1
    • Remove the two 5 mm Phillips screws above the controller ports.
  10. Nintendo Wii Fan Replacement: paso 10, imagen 1 de 1
    • Use a metal spudger to remove the three highlighted screw covers stuck to the side of the Wii.
  11. Nintendo Wii Fan Replacement: paso 11, imagen 1 de 1
    • Remove the following screws:
    • Two 5 mm Phillips screws
    • One 8.2 mm Tri-Point screw
  12. Nintendo Wii Fan Replacement: paso 12, imagen 1 de 1
    • Use a metal spudger to remove the two rubber feet stuck to the bottom face of the Wii near the rear ports.
  13. Nintendo Wii Fan Replacement: paso 13, imagen 1 de 1
    • Remove the two 8.2 mm Tri-Point screws hidden under the feet you just removed.
    • You may use a 4 mm hex driver to extend your bit into the recesses and reach the screws.
  14. Nintendo Wii Fan Replacement: paso 14, imagen 1 de 1
    • Lift the outer case straight up off the body of the Wii.
  15. Nintendo Wii Fan Replacement, Fan: paso 15, imagen 1 de 1
    • Grab the fan connector with a pair of tweezers and lift it straight up and out of its socket on the motherboard.
    • Be sure your tweezers are clamped down on the fan connector, not the socket attached to the motherboard.
  16. Nintendo Wii Fan Replacement: paso 16, imagen 1 de 1
    • Remove the two 10 mm Phillips screws securing the fan to the fan shroud.
  17. Nintendo Wii Fan Replacement: paso 17, imagen 1 de 1
    • Remove the fan from the Wii.
Conclusión
28 personas más completaron esta guía.
9 comentarios
Awesome guide, just replaced faulty fan unit in my 9 year old wii. Should hopefully keep it going for another 9 years :)
Finlay Macrae - Contestar
Super easy and great instructions! I feel a little guilty that my Wii sat in the garage for 4 years! Now it'll be a great birthday present for my 2 boys.
e_gayheart - Contestar
Does anyone have a diagram for the Wii’s airflow? I’m looking to install a booster fan at the bottom to help blow air in but I want to make sure it is effective.
Jessica Parnelli Fawkes - Contestar
nice¡¡¡¡¡¡¡¡¡¡¡¡¡¡
RIGO NOLASCO - Contestar
Thanks! Wii Quarantine’n in 2021!
Daniel Thomas - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 52
Ultimos 30 días: 264
Todo El Tiempo: 42,609
