Saltar al contenido principal
Introducción
Replacing the bottom panel requires removal of every component inside the Wii.
  1. Nintendo Wii Bottom Panel Replacement, Faceplate: paso 1, imagen 1 de 2 Nintendo Wii Bottom Panel Replacement, Faceplate: paso 1, imagen 2 de 2
    • Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
  2. Nintendo Wii Bottom Panel Replacement: paso 2, imagen 1 de 1
    • Remove the two 8.3 mm Tri-Wing screws hidden under the covers you just removed.
  3. Nintendo Wii Bottom Panel Replacement: paso 3, imagen 1 de 1
    • Remove the single 5.9 mm Phillips screw under the controller port door nearest the faceplate.
  4. Nintendo Wii Bottom Panel Replacement: paso 4, imagen 1 de 1
    • Use a metal spudger to remove the rubber foot stuck to the side of the Wii near the DVD drive opening.
  5. Nintendo Wii Bottom Panel Replacement: paso 5, imagen 1 de 1
    • Remove the single 5.9 mm Phillips screw hidden under the foot you just removed.
  6. Nintendo Wii Bottom Panel Replacement: paso 6, imagen 1 de 2 Nintendo Wii Bottom Panel Replacement: paso 6, imagen 2 de 2
    • Carefully pull the faceplate away from the front of the Wii.
    • Use a pair of tweezers to disconnect the LED cable's plastic connector from the motherboard.
    • Remove the faceplate.
  7. Nintendo Wii Bottom Panel Replacement, Outer Case: paso 7, imagen 1 de 3 Nintendo Wii Bottom Panel Replacement, Outer Case: paso 7, imagen 2 de 3 Nintendo Wii Bottom Panel Replacement, Outer Case: paso 7, imagen 3 de 3
    • Open the controller port cover until it is perpendicular to the black controller port bezel.
    • Pull the controller port cover straight up to release it from the outer case.
    • Repeat this procedure for the memory card port cover.
  8. Nintendo Wii Bottom Panel Replacement: paso 8, imagen 1 de 2 Nintendo Wii Bottom Panel Replacement: paso 8, imagen 2 de 2
    • Remove the two remaining 4.1 mm Phillips screws along the top edge of the black plastic controller port bezel.
    • Lift the bezel from the long edge furthest away from the controller ports and remove it from the Wii.
  9. Nintendo Wii Bottom Panel Replacement: paso 9, imagen 1 de 1
    • Remove the two 5 mm Phillips screws above the controller ports.
  10. Nintendo Wii Bottom Panel Replacement: paso 10, imagen 1 de 1
    • Use a metal spudger to remove the three highlighted screw covers stuck to the side of the Wii.
  11. Nintendo Wii Bottom Panel Replacement: paso 11, imagen 1 de 1
    • Remove the following screws:
    • Two 5 mm Phillips screws
    • One 8.2 mm Tri-Wing screw
  12. Nintendo Wii Bottom Panel Replacement: paso 12, imagen 1 de 1
    • Use a metal spudger to remove the two rubber feet stuck to the bottom face of the Wii near the rear ports.
  13. Nintendo Wii Bottom Panel Replacement: paso 13, imagen 1 de 1
    • Remove the two 8.2 mm Tri-Wing screws hidden under the feet you just removed.
  14. Nintendo Wii Bottom Panel Replacement: paso 14, imagen 1 de 1
    • Lift the outer case straight up off the body of the Wii.
  15. Nintendo Wii Bottom Panel Replacement, DVD Drive: paso 15, imagen 1 de 2 Nintendo Wii Bottom Panel Replacement, DVD Drive: paso 15, imagen 2 de 2
    • Remove the small Phillips screw securing the battery door to the bottom panel.
    • This screw is captive to the battery door.
    • Pull the battery door out of the Wii.
    • This is a good time to change the CR2032 battery if it hasn't been changed recently.
  16. Nintendo Wii Bottom Panel Replacement: paso 16, imagen 1 de 1
    • Remove the 8.2 mm Tri-Wing screw that was hidden beneath the battery door.
  17. Nintendo Wii Bottom Panel Replacement: paso 17, imagen 1 de 1
    • Remove the two 8.2 mm Tri-Wing screws securing the DVD drive shield near the controller ports.
  18. Nintendo Wii Bottom Panel Replacement: paso 18, imagen 1 de 1
    • Lift the DVD drive shield upward and remove it from the Wii.
  19. Nintendo Wii Bottom Panel Replacement: paso 19, imagen 1 de 1
    • Remove the four 9 mm #1 Phillips screws securing the DVD drive to the bottom panel.
  20. Nintendo Wii Bottom Panel Replacement: paso 20, imagen 1 de 1
    • Lift the side of the DVD drive opposite the controller ports enough to access the cables on its bottom face.
    • Carefully pull the DVD drive power cable out from under the plastic shroud near the heat sink.
  21. Nintendo Wii Bottom Panel Replacement: paso 21, imagen 1 de 1
    • Pull the DVD drive power cable away from its socket on the DVD drive.
  22. Nintendo Wii Bottom Panel Replacement: paso 22, imagen 1 de 2 Nintendo Wii Bottom Panel Replacement: paso 22, imagen 2 de 2
    • Use your fingernail to flip up the retaining flap on the DVD drive ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the DVD drive ribbon cable out of its socket.
    • Remove the DVD drive from the Wii.
  23. Nintendo Wii Bottom Panel Replacement, Motherboard Cover: paso 23, imagen 1 de 1
    • Use a pair of tweezers to lift the fan connector up and out of its socket on the logic board.
    • Be sure your tweezers are clamped down on the fan connector, not the socket on the motherboard.
  24. Nintendo Wii Bottom Panel Replacement: paso 24, imagen 1 de 2 Nintendo Wii Bottom Panel Replacement: paso 24, imagen 2 de 2
    • Remove the two 10 mm Phillips screws securing the fan to the fan shroud.
    • Remove the fan from the Wii.
  25. Nintendo Wii Bottom Panel Replacement: paso 25, imagen 1 de 2 Nintendo Wii Bottom Panel Replacement: paso 25, imagen 2 de 2
    • Use the tip of a spudger or another fine-pointed tool to carefully pry one of the black plastic retaining fingers attached to the fan shroud away from the Wi-Fi antenna board.
    • Lift the Wi-Fi antenna out of the fan shroud.
  26. Nintendo Wii Bottom Panel Replacement: paso 26, imagen 1 de 1
    • Remove the single 10 mm Phillips screw securing the second Wi-Fi antenna to the top of the fan shroud.
  27. Nintendo Wii Bottom Panel Replacement: paso 27, imagen 1 de 1
    • Remove the two pieces of tape securing the second Wi-Fi antenna cable to the plastic bracket near the heat sink.
  28. Nintendo Wii Bottom Panel Replacement: paso 28, imagen 1 de 1
    • Carefully de-route both antennas from the frame of the Wii and lay them aside.
  29. Nintendo Wii Bottom Panel Replacement: paso 29, imagen 1 de 2 Nintendo Wii Bottom Panel Replacement: paso 29, imagen 2 de 2
    • Remove the three 10 mm Phillips screws securing the fan shroud to the Wii.
    • Lift the fan shroud off the heat sink and remove it from the Wii.
  30. Nintendo Wii Bottom Panel Replacement: paso 30, imagen 1 de 3 Nintendo Wii Bottom Panel Replacement: paso 30, imagen 2 de 3 Nintendo Wii Bottom Panel Replacement: paso 30, imagen 3 de 3
    • Remove the following six screws securing the EMI fingers to the bottom panel:
    • Four 7 mm Phillips screws
    • Two 11.3 mm Phillips screws
    • Remove both sets of EMI fingers from the Wii.
  31. Nintendo Wii Bottom Panel Replacement: paso 31, imagen 1 de 2 Nintendo Wii Bottom Panel Replacement: paso 31, imagen 2 de 2
    • Remove the following three screws:
    • One 7 mm Phillips screw
    • Two 10 mm Phillips screws
    • Lift the bracket out of the Wii.
  32. Nintendo Wii Bottom Panel Replacement: paso 32, imagen 1 de 3 Nintendo Wii Bottom Panel Replacement: paso 32, imagen 2 de 3 Nintendo Wii Bottom Panel Replacement: paso 32, imagen 3 de 3
    • Remove the three 10 mm Phillips screws securing the black bracket to the bottom panel near the front of the Wii.
    • Slightly lift the bracket and use your other hand to pull the retaining clip away from where the Wi-Fi antennas enter the motherboard sheild.
    • Remove the bracket from the Wii.
    • Be sure not to lose the small square nut loosely held by the black plastic bracket.
  33. Nintendo Wii Bottom Panel Replacement: paso 33, imagen 1 de 1
    • Remove the nine remaining 7 mm Phillips screws securing the motherboard cover to the bottom panel.
  34. Nintendo Wii Bottom Panel Replacement: paso 34, imagen 1 de 1
    • Carefully lift the motherboard cover off the motherboard, minding any cables that may get caught.
    • On some models, a thermal pad for the wireless chip is attached to the underside of the motherboard cover. Be sure to replace it when reassembling.
  35. Nintendo Wii Bottom Panel Replacement, Heat Sink: paso 35, imagen 1 de 1
    • Remove the four 11.3 mm Phillips screws securing the heat sink to the bottom panel.
  36. Nintendo Wii Bottom Panel Replacement: paso 36, imagen 1 de 1
    • Lift the heat sink off the motherboard.
    • When working near the exposed processors, be sure not to disturb the thermal pads if you don't plan to replace them. They are fragile and can tear easily. If you do plan to replace the thermal pads, thermal paste can be used.
  37. Nintendo Wii Bottom Panel Replacement, Bottom Panel: paso 37, imagen 1 de 1
    • Lift the motherboard assembly off the bottom panel, minding any cables that may get caught.
    • Bottom panel remains.
    • Be sure to keep track of the small piece of foam highlighted in red.
Conclusión
7 personas más completaron esta guía.
2 comentarios
Hi, what is the purpose of the foam block in the last step? I've recently done a case mod, by my foam is not oriented correctly. Someone said this can cause issues. But I would like to know what exactly is its purpose.
Amlesh Sivanantham - Contestar
I used this to help tear down my Wii clean out a wad of dust and pet hair. Thanks for the guide!
spslizer - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 33
Ultimos 30 días: 132
Todo El Tiempo: 10,713
