Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Nintendo WaveBird Wireless Controller Channel Wheel Replacement
Qué necesitas
  1. Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Batteries: paso 1, imagen 1 de 2 Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Batteries: paso 1, imagen 2 de 2
    • Pull down on the battery cover release lever and pull back to remove the cover.
  2. Nintendo WaveBird Wireless Controller Channel Wheel Replacement: paso 2, imagen 1 de 1
    • Remove both batteries from the device.
  3. Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Front Panel: paso 3, imagen 1 de 2 Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Front Panel: paso 3, imagen 2 de 2
    • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
    • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
  4. Nintendo WaveBird Wireless Controller Channel Wheel Replacement: paso 4, imagen 1 de 2 Nintendo WaveBird Wireless Controller Channel Wheel Replacement: paso 4, imagen 2 de 2
    • Carefully turn over the controller and place it on a flat surface.
    • Slowly separate the top panel from the bottom panel.
    • The buttons are loose and may fall off the motherboard.
    • Once separated, set aside the top panel.
    • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
  5. Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Buttons: paso 5, imagen 1 de 3 Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Buttons: paso 5, imagen 2 de 3 Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Buttons: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Use tweezers to remove the buttons.
    • It may be easier to remove the A button off of the pad by lifting it with your fingers.
    • During reassembly, make sure all buttons are in their respective sockets so they match up with the front panel.
  6. Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Motherboard: paso 6, imagen 1 de 1
    • Using tweezers remove the three grey button pads from the motherboard.
  7. Nintendo WaveBird Wireless Controller Channel Wheel Replacement: paso 7, imagen 1 de 1
    • With your fingers gently grip the motherboard on both sides and lift it away from the back panel.
    • To put the motherboard back into place, align the two metal clips under the motherboard with the slots in the back panel. The motherboard should fall into place.
  8. Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Channel Wheel: paso 8, imagen 1 de 1
    • Turn the motherboard over so the channel wheel is facing up.
  9. Nintendo WaveBird Wireless Controller Channel Wheel Replacement: paso 9, imagen 1 de 2 Nintendo WaveBird Wireless Controller Channel Wheel Replacement: paso 9, imagen 2 de 2
    • Pinch the wheel and pull it away from the motherboard.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 10-40, Amido Spring 2013 Miembro de Cal Poly, Team 10-40, Amido Spring 2013
CPSU-AMIDO-S13S10G40
Miembros de 4
37 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 76
Todo El Tiempo: 2,674
