Saltar al contenido principal
Nintendo Switch Screen Replacement
Qué necesitas
  1. Nintendo Switch Screen Replacement, Release the Joy Con controller locking tabs: paso 1, imagen 1 de 3 Nintendo Switch Screen Replacement, Release the Joy Con controller locking tabs: paso 1, imagen 2 de 3 Nintendo Switch Screen Replacement, Release the Joy Con controller locking tabs: paso 1, imagen 3 de 3
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
  2. Nintendo Switch Screen Replacement, Remove the Joy Con controllers: paso 2, imagen 1 de 3 Nintendo Switch Screen Replacement, Remove the Joy Con controllers: paso 2, imagen 2 de 3 Nintendo Switch Screen Replacement, Remove the Joy Con controllers: paso 2, imagen 3 de 3
    • Continue sliding the Joy Con upward until it's completely removed from the console.
    • Repeat this same process for the other Joy Con.
  3. Nintendo Switch Screen Replacement, Remove the back-side screws: paso 3, imagen 1 de 1
    Herramienta utilizada en este paso:
    Magnetic Project Mat
    $19.95
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
  4. Nintendo Switch Screen Replacement, Remove the top and bottom screws: paso 4, imagen 1 de 2 Nintendo Switch Screen Replacement, Remove the top and bottom screws: paso 4, imagen 2 de 2
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following screws securing the rear panel:
    • One 2.5 mm-long screw on the top edge of the device
    • Two 2.5 mm-long screws on the bottom edge of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try another JIS 000 or PH 000 driver if the screws won't come out.
  5. Nintendo Switch Screen Replacement: paso 5, imagen 1 de 2 Nintendo Switch Screen Replacement: paso 5, imagen 2 de 2
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
  6. Nintendo Switch Screen Replacement: paso 6, imagen 1 de 2 Nintendo Switch Screen Replacement: paso 6, imagen 2 de 2
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
  7. Nintendo Switch Screen Replacement: paso 7, imagen 1 de 1
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the 1.6 mm screw in the kickstand well.
    • Close the kickstand.
  8. Nintendo Switch Screen Replacement: paso 8, imagen 1 de 3 Nintendo Switch Screen Replacement: paso 8, imagen 2 de 3 Nintendo Switch Screen Replacement: paso 8, imagen 3 de 3
    • Open the game card cartridge flap.
    • The game card cartridge flap attaches to the other half of the plastic shell, preventing you from completely lifting up the rear panel if it's closed.
    • Lift the rear panel up from the bottom of the device and remove it.
  9. Nintendo Switch Screen Replacement, Remove the microSD card reader: paso 9, imagen 1 de 1
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the 3.1 mm screw securing the microSD card reader to the device.
  10. Nintendo Switch Screen Replacement: paso 10, imagen 1 de 2 Nintendo Switch Screen Replacement: paso 10, imagen 2 de 2
    • Use your fingers or a pair of tweezers to lift the microSD card reader straight up from the device to disconnect and remove it.
    • During reassembly, make sure the press connector underneath the foam pad is firmly connected to the motherboard. It may help to remove the foam pad before reinstalling the card reader.
  11. Nintendo Switch Screen Replacement, Remove the shield plate: paso 11, imagen 1 de 1
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the six 3 mm screws securing the shield plate to the device.
  12. Nintendo Switch Screen Replacement: paso 12, imagen 1 de 2 Nintendo Switch Screen Replacement: paso 12, imagen 2 de 2
    • Use your fingers or a pair of tweezers to peel back the piece of foam on the top edge of the device near the fan exhaust port.
    • If the foam doesn't easily peel away, don't force it as it might end up tearing. Carefully peel at different spots to pull back the foam.
  13. Nintendo Switch Screen Replacement: paso 13, imagen 1 de 3 Nintendo Switch Screen Replacement: paso 13, imagen 2 de 3 Nintendo Switch Screen Replacement: paso 13, imagen 3 de 3
    • Insert a spudger underneath the shield plate along the edge of the device.
    • Pry up to lift the shield plate and remove it from the device.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. This helps prevent the Switch from overheating.
    • You can reuse the pink thermal compound if you're careful. Keep the compound clean and make sure it makes solid contact between the heat sink and the shield during reassembly.
    • If you need to replace it, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate compound, such as K5 Pro, during reassembly.
  14. Nintendo Switch Screen Replacement, Disconnect the battery: paso 14, imagen 1 de 2 Nintendo Switch Screen Replacement, Disconnect the battery: paso 14, imagen 2 de 2
    • Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
  15. Nintendo Switch Screen Replacement, Remove the heat sink: paso 15, imagen 1 de 1
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the three 3 mm screws securing the heat sink to the motherboard.
    • Carefully peel the two foam pieces stuck over both the heatsink and the fan away from the fan.
    • The foam only needs to be peeled back enough to clear the fan.
    • The foam is really delicate and tears easily. Use the following technique to peel the foam:
    • Insert the point of a spudger underneath the part of the foam that isn't stuck against anything,
    • Press the top of the foam with your finger to hold it in place.
    • Roll the spudger tip underneath the foam all the way to the other end of the foam to release it.
  16. Nintendo Switch Screen Replacement: paso 17, imagen 1 de 3 Nintendo Switch Screen Replacement: paso 17, imagen 2 de 3 Nintendo Switch Screen Replacement: paso 17, imagen 3 de 3
    • Use a spudger or your fingers to lift the heatsink up and off the motherboard to remove it.
    • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
    • Clean off the old thermal paste from the heat sink and CPU using high-concentration (90% or higher) isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly.
    • Apply thermal paste to all surfaces that had thermal paste applied previously. This includes between the heatpipe and aluminum shield, which the Switch uses as additional heatsinking.
  17. Nintendo Switch Screen Replacement, Remove the headphone jack and game card reader: paso 18, imagen 1 de 2 Nintendo Switch Screen Replacement, Remove the headphone jack and game card reader: paso 18, imagen 2 de 2
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the digitizer cable's ZIF connector.
  18. Nintendo Switch Screen Replacement: paso 19, imagen 1 de 2 Nintendo Switch Screen Replacement: paso 19, imagen 2 de 2
    • Use a pair of tweezers to slide the digitizer cable horizontally out of its connector on the game card reader board.
    • Before inserting the cable during reassembly, make sure the ZIF connector locking flap is flipped up.
    • With the cable parallel to the board, gently slide it into its connector.
    • Don't force the cable into the connector. If it doesn't insert, ensure the locking flap is flipped up, reposition the cable, and try again.
    • If your touchscreen doesn't work after the repair but your Game Card reader does, make sure this cable is properly inserted. If your Game Card reader also doesn't work, check the Game Card connector in the next step instead.
  19. Nintendo Switch Screen Replacement: paso 20, imagen 1 de 2 Nintendo Switch Screen Replacement: paso 20, imagen 2 de 2
    • Use the point of a spudger to pry the headphone jack and game card reader connector straight up to disconnect it from the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    • If the touch screen doesn't work and/or game cards aren't detected after reassembly, you might have not fully reconnected this press connector. Carefully disconnect it and try again.
  20. Nintendo Switch Screen Replacement: paso 21, imagen 1 de 1
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the three 3.1 mm screws securing the headphone jack and game card reader board to the device.
  21. Nintendo Switch Screen Replacement: paso 22, imagen 1 de 2 Nintendo Switch Screen Replacement: paso 22, imagen 2 de 2
    • Use a pair of tweezers or your fingers to remove the headphone jack bracket.
  22. Nintendo Switch Screen Replacement: paso 23, imagen 1 de 2 Nintendo Switch Screen Replacement: paso 23, imagen 2 de 2
    • Use a pair of tweezers or your fingers to remove the headphone jack and game card reader board.
  23. Nintendo Switch Screen Replacement, Screen: paso 24, imagen 1 de 2 Nintendo Switch Screen Replacement, Screen: paso 24, imagen 2 de 2
    • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the LCD ribbon cable ZIF connector.
  24. Nintendo Switch Screen Replacement: paso 25, imagen 1 de 2 Nintendo Switch Screen Replacement: paso 25, imagen 2 de 2
    • Use a pair of tweezers to pull the ribbon cable straight out of its connector on the motherboard.
  25. Nintendo Switch Screen Replacement: paso 26, imagen 1 de 2 Nintendo Switch Screen Replacement: paso 26, imagen 2 de 2
    • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the smaller LCD ribbon cable ZIF connector.
  26. Nintendo Switch Screen Replacement: paso 27, imagen 1 de 2 Nintendo Switch Screen Replacement: paso 27, imagen 2 de 2
  27. Nintendo Switch Screen Replacement: paso 28, imagen 1 de 1
    • Heat an iOpener and apply it to the bottom edge of the screen for around two minutes to to help soften the adhesive.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device—the display and internal battery are both susceptible to heat damage.
  28. Nintendo Switch Screen Replacement: paso 29, imagen 1 de 3 Nintendo Switch Screen Replacement: paso 29, imagen 2 de 3 Nintendo Switch Screen Replacement: paso 29, imagen 3 de 3
    • Apply a suction cup to the bottom-left corner of the screen.
    • Pull up on the suction up with strong, steady force to create a gap.
    • Depending on the age of your device, this may be difficult. If you have trouble, apply more heat and try again.
    • Insert the point of an opening pick into the gap, making sure to only insert the pick about 5 mm.
  29. Nintendo Switch Screen Replacement: paso 30, imagen 1 de 3 Nintendo Switch Screen Replacement: paso 30, imagen 2 de 3 Nintendo Switch Screen Replacement: paso 30, imagen 3 de 3
    • Slide the opening pick along the bottom edge of the screen to slice the adhesive.
    • Leave the pick inserted to prevent the adhesive from re-adhering to the frame.
  30. Nintendo Switch Screen Replacement: paso 31, imagen 1 de 3 Nintendo Switch Screen Replacement: paso 31, imagen 2 de 3 Nintendo Switch Screen Replacement: paso 31, imagen 3 de 3
    • Insert a second opening pick into the gap to the left of the first pick.
    • Slide the opening pick back towards the left side of the device.
    • Leave the opening pick inserted.
  31. Nintendo Switch Screen Replacement: paso 32, imagen 1 de 1
    • Heat the left edge of the screen for around two minutes to help soften the adhesive.
  32. Nintendo Switch Screen Replacement: paso 33, imagen 1 de 3 Nintendo Switch Screen Replacement: paso 33, imagen 2 de 3 Nintendo Switch Screen Replacement: paso 33, imagen 3 de 3
    • Continue sliding the opening pick around the bottom-left corner to slice the adhesive.
  33. Nintendo Switch Screen Replacement: paso 34, imagen 1 de 2 Nintendo Switch Screen Replacement: paso 34, imagen 2 de 2
    • Continue sliding the opening pick along the left edge of the screen to slice to adhesive.
  34. Nintendo Switch Screen Replacement: paso 35, imagen 1 de 1
    • Heat the top edge of the screen for around two minutes to help soften the adhesive.
  35. Nintendo Switch Screen Replacement: paso 36, imagen 1 de 3 Nintendo Switch Screen Replacement: paso 36, imagen 2 de 3 Nintendo Switch Screen Replacement: paso 36, imagen 3 de 3
    • Continue sliding the opening pick around the top-left corner of the screen to slice the adhesive.
  36. Nintendo Switch Screen Replacement: paso 37, imagen 1 de 3 Nintendo Switch Screen Replacement: paso 37, imagen 2 de 3 Nintendo Switch Screen Replacement: paso 37, imagen 3 de 3
    • Continue sliding the opening pick along the top edge of the screen to slice the adhesive.
  37. Nintendo Switch Screen Replacement: paso 38, imagen 1 de 3 Nintendo Switch Screen Replacement: paso 38, imagen 2 de 3 Nintendo Switch Screen Replacement: paso 38, imagen 3 de 3
    • Heat the right edge of the screen for around two minutes to help soften the adhesive.
    • Place the flat end of a spudger into the gap along the left edge of the screen.
    • Carefully and slowly lift the left edge of the screen, opening it like a book.
  38. Nintendo Switch Screen Replacement: paso 39, imagen 1 de 3 Nintendo Switch Screen Replacement: paso 39, imagen 2 de 3 Nintendo Switch Screen Replacement: paso 39, imagen 3 de 3
    • Lift the right edge of the screen straight off the device, threading the ribbon cables through the frame as you do so.
    • Take care not to snag any of the ribbon cables on the frame as you remove the screen.
    • You can reuse the screen adhesive if it is still sticky. Otherwise, replace the adhesive with double-sided tape such as Tesa tape.
Conclusión
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
If your new screen doesn’t work properly after you boot up the device, turn it back off and disconnect and reconnect the battery connector.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Answers community for help.
51 personas más completaron esta guía.
Craig Lloyd
Miembro Desde 02/10/16
39,333 Reputación
82 Guías creadas
4Guía Comentarios
What size tesa tape best fits the original (not OLED) switch? I have a slightly loose screen and don't want to disassemble to measure without having the right size on hand.
pvantilb05 - Contestar
I followed the steps, however the screen only works/lights up if I push on the screen. Any idea what I did wrong?
Hannah Henderson - Contestar
The Screen and Screen assembly are out of stock...can I buy the LCD, Digitizer etc and assemble them myself?
James Bowkett - Contestar
Step 27 - I pulled the ribbon connector off the board. Can I solder it back on?
mmhekh - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 45
Ultimos 7 días: 334
Ultimos 30 días: 1,683
Todo El Tiempo: 91,211
