Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
Follow this guide to replace a broken or faulty right Joy Con sensor rail on the Nintendo Switch game console.
Note: When you remove the shield plate, you’ll need to replace the thermal compound between the plate and the heatsink. Since normal thermal paste isn’t designed to bridge large gaps, the closest replacement is K5 Pro viscous thermal paste.
Note: This guide, and the part we sell, are compatible with the original Nintendo Switch model released in 2017, as well as the newer refreshed model released in 2019 (model numbers HAC-001 and HAC-001(-01), respectively).
  1. Before you begin this repair, make sure the device is completely powered off. Press and hold down the small round button on the back of the Joy Con controller. While you hold down the button, slide  the controller upward.
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
  2. Continue sliding the controller upward until it's completely removed from the console. Repeat this same process for the other controller. Repeat this same process for the other controller.
    • Continue sliding the controller upward until it's completely removed from the console.
    • Repeat this same process for the other controller.
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
  3. Use a JIS 000 screwdriver to remove the following screws securing the rear panel: One 2.5 mm-long screw on the top edge of the device
    • Use a JIS 000 screwdriver to remove the following screws securing the rear panel:
    • One 2.5 mm-long screw on the top edge of the device
    • Two 2.5 mm-long screws on the bottom edge of the device
  4. Use a JIS 000 screwdriver to remove the two 3.8 mm center screws on the sides of the device (one on each side). Use a JIS 000 screwdriver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
    • Use a JIS 000 screwdriver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
  5. Use your finger to flip up the kickstand on the back of the device. If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
  6. Use a JIS 000 screwdriver to remove the 1.6 mm screw in the kickstand well.
    • Use a JIS 000 screwdriver to remove the 1.6 mm screw in the kickstand well.
  7. Lift the rear panel up from the bottom of the device and remove it. Lift the rear panel up from the bottom of the device and remove it. Lift the rear panel up from the bottom of the device and remove it.
    • Lift the rear panel up from the bottom of the device and remove it.
  8. Use a JIS 000 screwdriver to remove the 3.1 mm screw securing the microSD card reader to the device.
    • Use a JIS 000 screwdriver to remove the 3.1 mm screw securing the microSD card reader to the device.
  9. Use your fingers or a pair of tweezers to lift the microSD card reader straight up from the device to disconnect and remove it. During reassembly, make sure the press connector underneath the foam pad is firmly connected to the motherboard. It may help to remove the foam pad before reinstalling the card reader.
    • Use your fingers or a pair of tweezers to lift the microSD card reader straight up from the device to disconnect and remove it.
    • During reassembly, make sure the press connector underneath the foam pad is firmly connected to the motherboard. It may help to remove the foam pad before reinstalling the card reader.
  10. Use a JIS 000 screwdriver to remove the six 3 mm screws securing the shield plate to the device.
    • Use a JIS 000 screwdriver to remove the six 3 mm screws securing the shield plate to the device.
  11. Use your fingers or a pair of tweezers to peel back the piece of foam on the top edge of the device near the fan exhaust port. Use your fingers or a pair of tweezers to peel back the piece of foam on the top edge of the device near the fan exhaust port.
    • Use your fingers or a pair of tweezers to peel back the piece of foam on the top edge of the device near the fan exhaust port.
  12. Insert a spudger underneath the shield plate along the edge of the device. Pry up to lift the shield plate up. You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • Insert a spudger underneath the shield plate along the edge of the device.
    • Pry up to lift the shield plate up.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • Remove the shield plate.
    • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. For best results, whenever the shield plate is removed, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate, thick compound such as K5 Pro during reassembly.
  13. Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard. Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
    • Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
  14. Use a spudger, opening tool, or your fingernail to flip up the small, hinged locking flap on the Joy Con rail data cable's ZIF connector. Use a spudger, opening tool, or your fingernail to flip up the small, hinged locking flap on the Joy Con rail data cable's ZIF connector.
    • Use a spudger, opening tool, or your fingernail to flip up the small, hinged locking flap on the Joy Con rail data cable's ZIF connector.
  15. Use a pair of tweezers to slide the Joy Con rail data cable out of its connector on the motherboard. Use a pair of tweezers to slide the Joy Con rail data cable out of its connector on the motherboard.
    • Use a pair of tweezers to slide the Joy Con rail data cable out of its connector on the motherboard.
  16. Use a JIS 000 screwdriver to remove the four 3.7 mm screws securing the right Joy Con rail to the frame of the device.
    • Use a JIS 000 screwdriver to remove the four 3.7 mm screws securing the right Joy Con rail to the frame of the device.
    • These screws are torqued down and can be difficult to remove. Make sure you're using a JIS screwdriver—not a Phillips screwdriver—during this procedure. Otherwise, you risk stripping the screws.
  17. Remove the right Joy Con sensor rail. Take care not to snag the rail's data cable on the device frame as you remove it.
    • Remove the right Joy Con sensor rail.
    • Take care not to snag the rail's data cable on the device frame as you remove it.
Conclusión
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Answers community for help.
22 personas más completaron esta guía.
Craig Lloyd
Miembro Desde 10/02/16
17,681 Reputación
81 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
134 Miembros
15,674 Guías creadas
Would you happen to know how to take out the screws if they’ve been stripped due to corrosion/rust? The back and site plate screws seem to have corroded and started to strip when I tried to unscrew them.
MrColorless - Contestar
I am running into same problem now. 3 out of 4 back screws are striped
Ryan Kindle -
This was a wonderful guide. Its straight forward, simple to understand, and doesnt pass over any steps large or small. Thank you to your team for what you do for us all.
Nicholas Bell - Contestar
what can i do if the bracket has snapped off of the consel?
and where could i purchase replacement parts
joe mama - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 42
Ultimos 7 días: 301
Ultimos 30 días: 1,326
Todo El Tiempo: 36,105
