Saltar al contenido principal
Nintendo Switch Heat Sink Replacement
Qué necesitas
  1. Nintendo Switch Heat Sink Replacement, Release the Joy Con controller locking tabs: paso 1, imagen 1 de 3 Nintendo Switch Heat Sink Replacement, Release the Joy Con controller locking tabs: paso 1, imagen 2 de 3 Nintendo Switch Heat Sink Replacement, Release the Joy Con controller locking tabs: paso 1, imagen 3 de 3
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
  2. Nintendo Switch Heat Sink Replacement, Remove the Joy Con controllers: paso 2, imagen 1 de 3 Nintendo Switch Heat Sink Replacement, Remove the Joy Con controllers: paso 2, imagen 2 de 3 Nintendo Switch Heat Sink Replacement, Remove the Joy Con controllers: paso 2, imagen 3 de 3
    • Continue sliding the Joy Con upward until it's completely removed from the console.
    • Repeat this same process for the other Joy Con.
  3. Nintendo Switch Heat Sink Replacement, Remove the back-side screws: paso 3, imagen 1 de 1
    Herramienta utilizada en este paso:
    Magnetic Project Mat
    $19.95
    Comprar
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
  4. Nintendo Switch Heat Sink Replacement, Remove the top and bottom screws: paso 4, imagen 1 de 2 Nintendo Switch Heat Sink Replacement, Remove the top and bottom screws: paso 4, imagen 2 de 2
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following screws securing the rear panel:
    • One 2.5 mm-long screw on the top edge of the device
    • Two 2.5 mm-long screws on the bottom edge of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try another JIS 000 or PH 000 driver if the screws won't come out.
  5. Nintendo Switch Heat Sink Replacement: paso 5, imagen 1 de 2 Nintendo Switch Heat Sink Replacement: paso 5, imagen 2 de 2
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
  6. Nintendo Switch Heat Sink Replacement: paso 6, imagen 1 de 2 Nintendo Switch Heat Sink Replacement: paso 6, imagen 2 de 2
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
  7. Nintendo Switch Heat Sink Replacement: paso 7, imagen 1 de 1
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the 1.6 mm screw in the kickstand well.
    • Close the kickstand.
  8. Nintendo Switch Heat Sink Replacement: paso 8, imagen 1 de 3 Nintendo Switch Heat Sink Replacement: paso 8, imagen 2 de 3 Nintendo Switch Heat Sink Replacement: paso 8, imagen 3 de 3
    • Open the game card cartridge flap.
    • The game card cartridge flap attaches to the other half of the plastic shell, preventing you from completely lifting up the rear panel if it's closed.
    • Lift the rear panel up from the bottom of the device and remove it.
  9. Nintendo Switch Heat Sink Replacement, Remove the microSD card reader: paso 9, imagen 1 de 1
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the 3.1 mm screw securing the microSD card reader to the device.
  10. Nintendo Switch Heat Sink Replacement: paso 10, imagen 1 de 2 Nintendo Switch Heat Sink Replacement: paso 10, imagen 2 de 2
    • Use your fingers or a pair of tweezers to lift the microSD card reader straight up from the device to disconnect and remove it.
    • During reassembly, make sure the press connector underneath the foam pad is firmly connected to the motherboard. It may help to remove the foam pad before reinstalling the card reader.
  11. Nintendo Switch Heat Sink Replacement, Remove the shield plate: paso 11, imagen 1 de 1
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the six 3 mm screws securing the shield plate to the device.
  12. Nintendo Switch Heat Sink Replacement: paso 12, imagen 1 de 2 Nintendo Switch Heat Sink Replacement: paso 12, imagen 2 de 2
    • Use your fingers or a pair of tweezers to peel back the piece of foam on the top edge of the device near the fan exhaust port.
    • If the foam doesn't easily peel away, don't force it as it might end up tearing. Carefully peel at different spots to pull back the foam.
  13. Nintendo Switch Heat Sink Replacement: paso 13, imagen 1 de 3 Nintendo Switch Heat Sink Replacement: paso 13, imagen 2 de 3 Nintendo Switch Heat Sink Replacement: paso 13, imagen 3 de 3
    • Insert a spudger underneath the shield plate along the edge of the device.
    • Pry up to lift the shield plate and remove it from the device.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. This helps prevent the Switch from overheating.
    • You can reuse the pink thermal compound if you're careful. Keep the compound clean and make sure it makes solid contact between the heat sink and the shield during reassembly.
    • If you need to replace it, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate compound, such as K5 Pro, during reassembly.
  14. Nintendo Switch Heat Sink Replacement, Disconnect the battery: paso 14, imagen 1 de 2 Nintendo Switch Heat Sink Replacement, Disconnect the battery: paso 14, imagen 2 de 2
    • Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
  15. Nintendo Switch Heat Sink Replacement, Remove the heat sink: paso 15, imagen 1 de 1
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the three 3 mm screws securing the heat sink to the motherboard.
    • Carefully peel the two foam pieces stuck over both the heatsink and the fan away from the fan.
    • The foam only needs to be peeled back enough to clear the fan.
    • The foam is really delicate and tears easily. Use the following technique to peel the foam:
    • Insert the point of a spudger underneath the part of the foam that isn't stuck against anything,
    • Press the top of the foam with your finger to hold it in place.
    • Roll the spudger tip underneath the foam all the way to the other end of the foam to release it.
  16. Nintendo Switch Heat Sink Replacement: paso 17, imagen 1 de 3 Nintendo Switch Heat Sink Replacement: paso 17, imagen 2 de 3 Nintendo Switch Heat Sink Replacement: paso 17, imagen 3 de 3
    • Use a spudger or your fingers to lift the heatsink up and off the motherboard to remove it.
    • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
    • Clean off the old thermal paste from the heat sink and CPU using high-concentration (90% or higher) isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly.
    • Apply thermal paste to all surfaces that had thermal paste applied previously. This includes between the heatpipe and aluminum shield, which the Switch uses as additional heatsinking.
Conclusión
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Answers community for help.
48 personas más completaron esta guía.
Craig Lloyd
Miembro Desde 02/10/16
35,351 Reputación
82 Guías creadas
9 comentarios
I couldn’t even get past the first step because my screws were in so tight I made them threadbare trying to get them out. I did use the iFixit toolkit so I was using the right head but taking the screws out is not as easy as demonstrated lol
Nate Topical - Contestar
same mines are stripped
Luigi Igii -
Same happened to me :( I was able to file down the screwdriver I was given and it worked on three of the screws before they’d stripped too much. The fourth screw I couldn’t remove so I was able to slightly bend and turn the backing enough to access the fan. I also wasn’t able to peel the tape back without it completely disintegrating. Haha guess I don’t have the magic touch.
Angela Evans -
Do you need the K5 thermal peas or is the Arctic silver 5 thermal paste enough?
Carlos O - Contestar
You just need a good thermal paste
Daniele Carminati -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 49
Ultimos 7 días: 268
Ultimos 30 días: 1,370
Todo El Tiempo: 73,403
