Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Nintendo Switch 2 Kickstand Replacement
Qué necesitas
  1. Nintendo Switch 2 Kickstand Replacement, Power off the console: paso 1, imagen 1 de 3 Nintendo Switch 2 Kickstand Replacement, Power off the console: paso 1, imagen 2 de 3 Nintendo Switch 2 Kickstand Replacement, Power off the console: paso 1, imagen 3 de 3
    • For your safety, discharge the battery below 25% before disassembling the console. This reduces the risk of a fire if the battery is damaged during the repair. If the battery is swollen, take appropriate precautions.
    • Remove any game cards and disconnect any cables, controllers, or other accessories from the console.
    • Power off the console by holding down the power button, selecting Power Options, then pressing Power Off.
  2. Nintendo Switch 2 Kickstand Replacement, Remove the bottom screws: paso 2, imagen 1 de 2 Nintendo Switch 2 Kickstand Replacement, Remove the bottom screws: paso 2, imagen 2 de 2
    • Use a JIS 00 driver to remove the two 3.1 mm‑long screws on either side of the bottom USB-C port.
    • You can try a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping the screw. Push down firmly on the driver and twist slowly.
  3. Nintendo Switch 2 Kickstand Replacement, Remove the top screw: paso 3, imagen 1 de 2 Nintendo Switch 2 Kickstand Replacement, Remove the top screw: paso 3, imagen 2 de 2
    • Use a JIS 00 driver to remove the 3.1 mm‑long screw on the top edge of the console (next to the ventilation cutouts).
  4. Nintendo Switch 2 Kickstand Replacement, Heat the right side sticker: paso 4, imagen 1 de 1
    • The Switch 2 has stickers on either side that need to removed to access the screws securing the back cover. It's easy to damage the stickers during removal, but you can mitigate this by regularly reheating the stickers and working carefully.
    • Use a hair dryer or heat gun to heat the sticker on the right side of the console, labeled with a "+" symbol, until it's hot to the touch.
    • You can use the kickstand to prop the console up vertically for easier access.
    • If you're using a heat gun, set it to low to avoid melting the plastic edge of the console.
  5. Nintendo Switch 2 Kickstand Replacement, Pry up the right side sticker: paso 5, imagen 1 de 3 Nintendo Switch 2 Kickstand Replacement, Pry up the right side sticker: paso 5, imagen 2 de 3 Nintendo Switch 2 Kickstand Replacement, Pry up the right side sticker: paso 5, imagen 3 de 3
    • The pointed end of the tweezers can damage the sticker from the underside, leaving a noticeable mark. If it's difficult to lift, apply more heat instead of using more force.
    • Slide one arm of angled tweezers underneath the sticker from its cutout around the right Joy‑Con 2 connector.
    • Gently pry up on the sticker until it starts to lift from the console.
    • Leave the tweezers in place to keep the sticker lifted.
  6. Nintendo Switch 2 Kickstand Replacement: paso 6, imagen 1 de 3 Nintendo Switch 2 Kickstand Replacement: paso 6, imagen 2 de 3 Nintendo Switch 2 Kickstand Replacement: paso 6, imagen 3 de 3
    Herramienta utilizada en este paso:
    Jimmy
    $7.95
    • Insert the tip of a Jimmy into the gap formed between the long edge of the console and the sticker.
    • Gently pry up the sticker, working your way up the long edge until the top of the sticker is separated from the console.
    • Remove the tweezers once the sticker is lifted.
    • You can leave the Jimmy in place to hold the top of the sticker off the frame—if it falls back into its recess, repeat this procedure to lift it back up.
  7. Nintendo Switch 2 Kickstand Replacement, Heat the right side sticker: paso 7, imagen 1 de 1
    • Reheat the bottom of the right side until it's hot to the touch.
  8. Nintendo Switch 2 Kickstand Replacement, Remove the right side sticker: paso 8, imagen 1 de 3 Nintendo Switch 2 Kickstand Replacement, Remove the right side sticker: paso 8, imagen 2 de 3 Nintendo Switch 2 Kickstand Replacement, Remove the right side sticker: paso 8, imagen 3 de 3
    • Carefully lift the sticker over the Joy‑Con 2 connector, then peel it up fully to remove it.
  9. Nintendo Switch 2 Kickstand Replacement, Remove the left side sticker: paso 9, imagen 1 de 3 Nintendo Switch 2 Kickstand Replacement, Remove the left side sticker: paso 9, imagen 2 de 3 Nintendo Switch 2 Kickstand Replacement, Remove the left side sticker: paso 9, imagen 3 de 3
    • Repeat this procedure to remove the sticker along the left side of the console, labeled with a "-" symbol.
  10. Nintendo Switch 2 Kickstand Replacement, Remove the side screws: paso 10, imagen 1 de 2 Nintendo Switch 2 Kickstand Replacement, Remove the side screws: paso 10, imagen 2 de 2
    • Use a JIS 00 driver to remove the two 3.6 mm‑long gold screws on each side of the console (four in total).
  11. Nintendo Switch 2 Kickstand Replacement, Open the kickstand: paso 11, imagen 1 de 3 Nintendo Switch 2 Kickstand Replacement, Open the kickstand: paso 11, imagen 2 de 3 Nintendo Switch 2 Kickstand Replacement, Open the kickstand: paso 11, imagen 3 de 3
    • Use your fingers to flip up the kickstand on the back of the console.
    • If there's a microSD Express card installed, remove it now before you continue to the next step.
  12. Nintendo Switch 2 Kickstand Replacement, Remove the back-side screws: paso 12, imagen 1 de 2 Nintendo Switch 2 Kickstand Replacement, Remove the back-side screws: paso 12, imagen 2 de 2
    • Use a Y00 driver to remove the two 4.4 mm‑long screws in the kickstand cutout.
  13. Nintendo Switch 2 Kickstand Replacement, Insert an opening pick: paso 13, imagen 1 de 2 Nintendo Switch 2 Kickstand Replacement, Insert an opening pick: paso 13, imagen 2 de 2
    • Insert an opening pick into the gap between the back cover and speaker cutout on the bottom edge of the console.
  14. Nintendo Switch 2 Kickstand Replacement: paso 14, imagen 1 de 2 Nintendo Switch 2 Kickstand Replacement: paso 14, imagen 2 de 2
    • Slide the opening pick towards the USB-C port until it's underneath the screw hole next to the port.
  15. Nintendo Switch 2 Kickstand Replacement, Insert a second opening pick: paso 15, imagen 1 de 3 Nintendo Switch 2 Kickstand Replacement, Insert a second opening pick: paso 15, imagen 2 de 3 Nintendo Switch 2 Kickstand Replacement, Insert a second opening pick: paso 15, imagen 3 de 3
    • Insert a second opening pick underneath the screw hole on the opposite side of the USB-C port, and slide it to the corner of the console.
  16. Nintendo Switch 2 Kickstand Replacement: paso 16, imagen 1 de 2 Nintendo Switch 2 Kickstand Replacement: paso 16, imagen 2 de 2
    • Slide the first opening pick back to where it was first inserted.
  17. Nintendo Switch 2 Kickstand Replacement, Remove the back cover: paso 17, imagen 1 de 3 Nintendo Switch 2 Kickstand Replacement, Remove the back cover: paso 17, imagen 2 de 3 Nintendo Switch 2 Kickstand Replacement, Remove the back cover: paso 17, imagen 3 de 3
    • Be careful not to drop your console. Once the back cover pops up, the opening picks will fall out of place.
    • Hold the console with two hands. Rest your thumbs on the opening picks.
    • Push up on the opening picks to lift the back cover until it pops up above the USB-C port.
  18. Nintendo Switch 2 Kickstand Replacement: paso 18, imagen 1 de 3 Nintendo Switch 2 Kickstand Replacement: paso 18, imagen 2 de 3 Nintendo Switch 2 Kickstand Replacement: paso 18, imagen 3 de 3
    • Lift the back cover up from the bottom edge and remove it.
  19. Nintendo Switch 2 Kickstand Replacement, Remove the upper hinge covers: paso 19, imagen 1 de 2 Nintendo Switch 2 Kickstand Replacement, Remove the upper hinge covers: paso 19, imagen 2 de 2
    • Use the flat end of a spudger to pry up one of the hinge's plastic upper hinge covers until it "pops" up.
  20. Nintendo Switch 2 Kickstand Replacement: paso 20, imagen 1 de 2 Nintendo Switch 2 Kickstand Replacement: paso 20, imagen 2 de 2
    • Pull the upper hinge cover out from underneath the lower hinge cover to remove it.
    • The cover is clipped in place and requires a little bit of force to remove.
  21. Nintendo Switch 2 Kickstand Replacement: paso 21, imagen 1 de 3 Nintendo Switch 2 Kickstand Replacement: paso 21, imagen 2 de 3 Nintendo Switch 2 Kickstand Replacement: paso 21, imagen 3 de 3
    • Repeat this process to remove the upper hinge cover on the other hinge.
  22. Nintendo Switch 2 Kickstand Replacement, Remove the kickstand screws: paso 22, imagen 1 de 2 Nintendo Switch 2 Kickstand Replacement, Remove the kickstand screws: paso 22, imagen 2 de 2
    • Use a JIS 00 driver to remove the two 2.3 mm‑long silver screws securing each hinge to the inside of the back cover (four total).
  23. Nintendo Switch 2 Kickstand Replacement, Remove the kickstand: paso 23, imagen 1 de 3 Nintendo Switch 2 Kickstand Replacement, Remove the kickstand: paso 23, imagen 2 de 3 Nintendo Switch 2 Kickstand Replacement, Remove the kickstand: paso 23, imagen 3 de 3
    • Open the kickstand to a 45‑degree angle and pull it out of the back cover to remove it.
  24. Nintendo Switch 2 Kickstand Replacement, Disassembly complete: paso 24, imagen 1 de 1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your console.
  25. Nintendo Switch 2 Kickstand Replacement, Install the kickstand: paso 25, imagen 1 de 3 Nintendo Switch 2 Kickstand Replacement, Install the kickstand: paso 25, imagen 2 de 3 Nintendo Switch 2 Kickstand Replacement, Install the kickstand: paso 25, imagen 3 de 3
    • Align the kickstand so its hinge covers are facing the back cover.
    • Insert the hinges through their slots in the back cover and set the kickstand into its cutout.
  26. Nintendo Switch 2 Kickstand Replacement, Install the kickstand screws: paso 26, imagen 1 de 2 Nintendo Switch 2 Kickstand Replacement, Install the kickstand screws: paso 26, imagen 2 de 2
    • Use a JIS 00 driver to install the two 2.3 mm‑long silver screws securing each hinge to the inside of the back cover (four total).
  27. Nintendo Switch 2 Kickstand Replacement, Install the upper hinge covers: paso 27, imagen 1 de 3 Nintendo Switch 2 Kickstand Replacement, Install the upper hinge covers: paso 27, imagen 2 de 3 Nintendo Switch 2 Kickstand Replacement, Install the upper hinge covers: paso 27, imagen 3 de 3
    • Align one of the upper hinge covers with its respective hinge, and slide it underneath the lower hinge cover.
    • Use your finger to press the upper hinge cover down until it clicks into place.
  28. Nintendo Switch 2 Kickstand Replacement: paso 28, imagen 1 de 3 Nintendo Switch 2 Kickstand Replacement: paso 28, imagen 2 de 3 Nintendo Switch 2 Kickstand Replacement: paso 28, imagen 3 de 3
    • Repeat this process to install the other upper hinge cover.
  29. Nintendo Switch 2 Kickstand Replacement, Prepare the back cover: paso 29, imagen 1 de 3 Nintendo Switch 2 Kickstand Replacement, Prepare the back cover: paso 29, imagen 2 de 3 Nintendo Switch 2 Kickstand Replacement, Prepare the back cover: paso 29, imagen 3 de 3
    • Fully pull out the game card tray.
    • Double-check the power and volume buttons to ensure they're seated correctly. If the rubber membrane beneath the buttons is out of place, ensure it's aligned with its pegs.
    • Check the microphone to ensure it's fully seated in its slot in the frame.
  30. Nintendo Switch 2 Kickstand Replacement, Install the back cover: paso 30, imagen 1 de 3 Nintendo Switch 2 Kickstand Replacement, Install the back cover: paso 30, imagen 2 de 3 Nintendo Switch 2 Kickstand Replacement, Install the back cover: paso 30, imagen 3 de 3
    • Align the top of the back cover with the top of the console.
    • Set the top edge of the back cover into place, checking the buttons and ports to ensure they're aligned properly. If they aren't, lift the back cover and try again.
    • Press along the top edge to fasten the clips securing the back cover to the console.
  31. Nintendo Switch 2 Kickstand Replacement: paso 31, imagen 1 de 2 Nintendo Switch 2 Kickstand Replacement: paso 31, imagen 2 de 2
    • Squeeze the rest of the back cover and console together to fasten the clips.
  32. Nintendo Switch 2 Kickstand Replacement, Install the back-side screws: paso 32, imagen 1 de 3 Nintendo Switch 2 Kickstand Replacement, Install the back-side screws: paso 32, imagen 2 de 3 Nintendo Switch 2 Kickstand Replacement, Install the back-side screws: paso 32, imagen 3 de 3
    • Use a JIS 00 driver to install the three 3.1 mm‑long screws securing the back cover: one on the top edge of the console, and two on either side of the bottom USB-C port.
    • Use a Y00 driver to install the two 4.4 mm‑long screws in the kickstand cutout.
  33. Nintendo Switch 2 Kickstand Replacement, Install the side screws: paso 33, imagen 1 de 2 Nintendo Switch 2 Kickstand Replacement, Install the side screws: paso 33, imagen 2 de 2
    • Install the two 3.6 mm‑long gold screws on each side of the console (four in total).
  34. Nintendo Switch 2 Kickstand Replacement, Test the console: paso 34, imagen 1 de 2 Nintendo Switch 2 Kickstand Replacement, Test the console: paso 34, imagen 2 de 2
    • Power on the console and test functionality to ensure it's working as expected.
  35. Nintendo Switch 2 Kickstand Replacement, Install the stickers: paso 35, imagen 1 de 3 Nintendo Switch 2 Kickstand Replacement, Install the stickers: paso 35, imagen 2 de 3 Nintendo Switch 2 Kickstand Replacement, Install the stickers: paso 35, imagen 3 de 3
    • Align the right side sticker with its recess. Ensure the cutout in the sticker is aligned with the Joy-Con connector.
    • Set the sticker into its recess, first on one side, then the other.
    • Use your finger or the flat end of a spudger to press the sticker into place.
    • If the sticker isn't sticking well, apply heat after you press it into place.
  36. Nintendo Switch 2 Kickstand Replacement: paso 36, imagen 1 de 3 Nintendo Switch 2 Kickstand Replacement: paso 36, imagen 2 de 3 Nintendo Switch 2 Kickstand Replacement: paso 36, imagen 3 de 3
    • Repeat this procedure to install the left side sticker.
Conclusión
You finished fixing your Switch 2!
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch 2 Answers Community for help.
Nick Schultz
Miembro Desde 03/24/24
46,177 Reputación
254 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 11
Ultimos 7 días: 68
Ultimos 30 días: 236
Todo El Tiempo: 1,139
