Saltar al contenido principal
Nintendo NES Advantage Circuit Board Replacement
Qué necesitas
  1. Nintendo NES Advantage Circuit Board Replacement, Back Panel: paso 1, imagen 1 de 1
    • Remove the four sticky pads from the bottom of the device.
    • If the pads are stuck, use a spudger to remove them.
  2. Nintendo NES Advantage Circuit Board Replacement: paso 2, imagen 1 de 2 Nintendo NES Advantage Circuit Board Replacement: paso 2, imagen 2 de 2
    • Remove the six 8 mm screws from the bottom of the device with a Phillips #0 screwdriver.
    • Use your hands to pull the back panel away from the controller.
  3. Nintendo NES Advantage Circuit Board Replacement, Circuit Board: paso 3, imagen 1 de 2 Nintendo NES Advantage Circuit Board Replacement, Circuit Board: paso 3, imagen 2 de 2
    • Remove the three 14 mm screws from the gray cross with a Phillips #0 screwdriver.
    • Lift the gray component away from the device.
  4. Nintendo NES Advantage Circuit Board Replacement: paso 4, imagen 1 de 1
    • Lift up the black wire and move it to the side.
  5. Nintendo NES Advantage Circuit Board Replacement: paso 5, imagen 1 de 3 Nintendo NES Advantage Circuit Board Replacement: paso 5, imagen 2 de 3 Nintendo NES Advantage Circuit Board Replacement: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Remove the two silver knobs on the front of the device.
    • Unscrew the two silver nuts using a flathead screwdriver.
    • Remove each silver nut and silver washer using a pair of tweezers.
  6. Nintendo NES Advantage Circuit Board Replacement: paso 6, imagen 1 de 2 Nintendo NES Advantage Circuit Board Replacement: paso 6, imagen 2 de 2
    • Remove the remaining three 8 mm screws on the circuit board with a Phillips #0 screwdriver.
    • Remove the silver bracket from the top of the circuit board.
  7. Nintendo NES Advantage Circuit Board Replacement: paso 7, imagen 1 de 1
    • Remove the circuit board from the controller.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 22
Todo El Tiempo: 431
