Introducción
Removing the top case will allow you access to the GameCube's internal parts.
Qué necesitas
Turn over the Gamecube so that the bottom side is facing up.
Use the 4.5 mm Gamebit screwdriver to remove all four screws.
12 personas más completaron esta guía.
Un comentario
Can you do a more in-depth version of the top cover? I had to clean each piece and need help figuring out where all the pieces go. Thanks
