Saltar al contenido principal
Introducción
The Z button is located above the right trigger but functions as a button.
Partes
No se especificaron partes.
  1. Place the controller (buttons down) on a solid surface.
    • Place the controller (buttons down) on a solid surface.
    • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
  2. Gently lift the back panel up, separating it from the front panel.
    • Gently lift the back panel up, separating it from the front panel.
    • Some of the buttons may fall out if they are knocked around.
  3. Grab the Z-button by the peg with tweezers and lift it out of the controller. During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
    • Grab the Z-button by the peg with tweezers and lift it out of the controller.
    • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
Conclusión
4 personas más completaron esta guía.
Sean Michel
Miembro Desde 14/01/13
1,873 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 19-44, Regan Winter 2013 Miembro de Cal Poly, Team 19-44, Regan Winter 2013
CPSU-REGAN-W13S19G44
4 Miembros
26 Guías creadas
My z button presses down and makes the click, but it does not actually send any input to the controller. How do you fix this?
Augustine Park - Contestar
So how do you put it back in like the replacement because I have a controller I'm working with a junker my Friend gave me and I'm trying to fix it the z button doesn't work here is a pic
Justin Sebastian - Contestar
My bad no pic it's a pelican wireless controller
Justin Sebastian -
How do you change the spring? I have replacement z buttons just no spring for them…
Gaf Epar - Contestar
Does that silver bar on the bottom of the Z button supposed to be there? My Z button does not have that, is it important for the button to have that?
Kevin Alaniz - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 38
Ultimos 30 días: 106
Todo El Tiempo: 14,457
