Saltar al contenido principal
Nintendo GameCube Controller Triggers Replacement
Qué necesitas
  1. Nintendo GameCube Controller Triggers Replacement, Back Panel: paso 1, imagen 1 de 1
    • Place the controller (buttons down) on a solid surface.
    • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
  2. Nintendo GameCube Controller Triggers Replacement: paso 2, imagen 1 de 1
    • Gently lift the back panel up, separating it from the front panel.
    • Some of the buttons may fall out if they are knocked around.
  3. Nintendo GameCube Controller Triggers Replacement, Z Button: paso 3, imagen 1 de 2 Nintendo GameCube Controller Triggers Replacement, Z Button: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Grab the Z-button by the peg with tweezers and lift it out of the controller.
    • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
  4. Nintendo GameCube Controller Triggers Replacement, Circuit Board: paso 4, imagen 1 de 1
    • Carefully unhook the cable that is looped around the peg.
  5. Nintendo GameCube Controller Triggers Replacement: paso 5, imagen 1 de 1
    • Lift the circuit board out of the controller.
    • Do not grab the rumble motor to lift the circuit board as shown in the picture. It will in many cases just remove the rumble motor. Instead, grab the edges of the board.
  6. Nintendo GameCube Controller Triggers Replacement, Triggers: paso 6, imagen 1 de 1
    • Remove the two 8.9mm Phillips Head #0 screws.
  7. Nintendo GameCube Controller Triggers Replacement: paso 7, imagen 1 de 1
    • Remove black cover.
  8. Nintendo GameCube Controller Triggers Replacement: paso 8, imagen 1 de 3 Nintendo GameCube Controller Triggers Replacement: paso 8, imagen 2 de 3 Nintendo GameCube Controller Triggers Replacement: paso 8, imagen 3 de 3
    • To remove the trigger assembly, depress the trigger with your index finger as if you are using the controller normally.
    • Hold the grey square bracket onside of the controller with your thumb.
    • Keep your fingers in the same place while rotating upwards towards you to remove trigger assembly.
  9. Nintendo GameCube Controller Triggers Replacement: paso 9, imagen 1 de 1
    • Pull the metal clip from the trigger.
Conclusión
In order to remove the other trigger, simply repeat Steps 6 through Step 9 on the right side.
11 personas más completaron esta guía.
Sean Michel
Miembro Desde 01/14/13
2,496 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 19-44, Regan Winter 2013 Miembro de Cal Poly, Team 19-44, Regan Winter 2013
CPSU-REGAN-W13S19G44
4 Miembros
26 Guías creadas
2 comentarios
Don't forget to aline the trigger slider holes and the slider pins on the board when putting it all back together.
buttpug - Contestar
Hallo ich habe da mal eine Frage. Ist es möglich die Empfindlichkeit der Trigger zu beeinflussen ? Leider reagieren sie erst sehr spät da mann den Knopf sehr weit hereindrücken muss.
danke schon mal
Otti
Ottitrotti - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 28
Ultimos 30 días: 122
Todo El Tiempo: 27,222
