Saltar al contenido principal
Nintendo Game Boy Advance SP Battery Replacement
Qué necesitas
  1. Nintendo Game Boy Advance SP Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Use a standard Phillips #00 screwdriver to loosen the 4 mm screw that keeps the battery cover attached to the device.
  2. Nintendo Game Boy Advance SP Battery Replacement: paso 2, imagen 1 de 1
    • Lift the battery cover up and remove it from the device.
    • The screw will remain attached to the battery cover because of Nintendo's design.
  3. Nintendo Game Boy Advance SP Battery Replacement: paso 3, imagen 1 de 1
    • Use your fingers or a plastic opening tool to remove the battery from the device.
    • Caution: Please exercise caution when handling the battery. If it appears to be swelling or damaged at all it is considered a fire hazard.
Conclusión
For reassembly, follow the instructions in reverse order.
30 personas más completaron esta guía.
Rocco Lattanzio
Miembro Desde 01/11/13
1,006 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 17-22, Forte Winter 2013 Miembro de Cal Poly, Team 17-22, Forte Winter 2013
CPSU-FORTE-W13S17G22
4 Miembros
39 Guías creadas
2 comentarios
This task is not very easy, its easy.
Very easy: Does not require opening device.
Easy: Requires minimal disassembly and requires a few tools like a Philips or flat-head screwdriver.
This however requires opening device.
Santi12008 - Contestar
Thanks for yout guideline. I settle in 5 minutes.
aam9999 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 35
Ultimos 7 días: 227
Ultimos 30 días: 1,003
Todo El Tiempo: 65,270
