Saltar al contenido principal
Nintendo Entertainment System Controller Cable Replacement
Qué necesitas
  1. Nintendo Entertainment System Controller Cable Replacement, Back Cover Removal: paso 1, imagen 1 de 2 Nintendo Entertainment System Controller Cable Replacement, Back Cover Removal: paso 1, imagen 2 de 2
    • Remove the 6 8mm screws in the back cover using a #1 Philips screwdriver.
  2. Nintendo Entertainment System Controller Cable Replacement, Loosen Cable: paso 2, imagen 1 de 1
    • Lift the back cover off the controller.
    • Remove the cable from its holders to facilitate PCB removal.
  3. Nintendo Entertainment System Controller Cable Replacement, PCB Removal: paso 3, imagen 1 de 1
    • Lift the PCB straight up and out of the controller. Turn the board over to access the solder joints for the cable.
    • Desolder the 5 connections and solder in your new cable.
    • Wire colors are printed on the reverse side of the board.
Conclusión
Una persona más ha completado esta guía.
themap504
Miembro Desde 01/08/15
80 Reputación
1 Guía escrita
Un comentario
My replacement plugs have different colors. Colors are yellow, white, red, black, and green. I’m also doing a max controller not regular nes controller. The max has yellow, red, white, red, and orange color schemes. Any advice. I wired up same colors and guessed for rest. figured black could replace one of the reds, and used green to replace orange, but console just resets over and over with that controller plugged in.
Daniel Melvin - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 25
Todo El Tiempo: 1,880
