Saltar al contenido principal
Nintendo DSi XL Volume Buttons Replacement
Qué necesitas
  1. Nintendo DSi XL Volume Buttons Replacement, Battery: paso 1, imagen 1 de 2 Nintendo DSi XL Volume Buttons Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Nintendo DSi XL Volume Buttons Replacement: paso 2, imagen 1 de 1
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Volume Buttons Replacement, Lower Case: paso 3, imagen 1 de 3 Nintendo DSi XL Volume Buttons Replacement, Lower Case: paso 3, imagen 2 de 3 Nintendo DSi XL Volume Buttons Replacement, Lower Case: paso 3, imagen 3 de 3
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Nintendo DSi XL Volume Buttons Replacement: paso 4, imagen 1 de 1
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Nintendo DSi XL Volume Buttons Replacement: paso 5, imagen 1 de 3 Nintendo DSi XL Volume Buttons Replacement: paso 5, imagen 2 de 3 Nintendo DSi XL Volume Buttons Replacement: paso 5, imagen 3 de 3
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Nintendo DSi XL Volume Buttons Replacement: paso 6, imagen 1 de 2 Nintendo DSi XL Volume Buttons Replacement: paso 6, imagen 2 de 2
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Nintendo DSi XL Volume Buttons Replacement: paso 7, imagen 1 de 2 Nintendo DSi XL Volume Buttons Replacement: paso 7, imagen 2 de 2
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  8. Nintendo DSi XL Volume Buttons Replacement, Volume Control Switch: paso 8, imagen 1 de 1
    • On the inside of the battery compartment, use the tip of a spudger to detach the metal latch securing the volume control switch in place.
    • The latch will only move about 1 mm.
  9. Nintendo DSi XL Volume Buttons Replacement: paso 9, imagen 1 de 3 Nintendo DSi XL Volume Buttons Replacement: paso 9, imagen 2 de 3 Nintendo DSi XL Volume Buttons Replacement: paso 9, imagen 3 de 3
    • Using the flat end of a spudger, remove the adhesive securing the volume control switch ribbon cable to the back of the battery compartment.
    • Using the flat of a spudger, pry the volume control switch straight up out of the lower case.
    • Remove the volume control switch from the DSi XL.
  10. Nintendo DSi XL Volume Buttons Replacement: paso 10, imagen 1 de 1
    • Using the flat end of a spudger, remove the volume control buttons from the metal backing bracket.
    • The bracket is attached by a strong adhesive. Work slowly and carefully, being sure to not damage the ribbon cable.
    • Volume control switch remains.
  11. Nintendo DSi XL Volume Buttons Replacement, Volume Buttons: paso 11, imagen 1 de 3 Nintendo DSi XL Volume Buttons Replacement, Volume Buttons: paso 11, imagen 2 de 3 Nintendo DSi XL Volume Buttons Replacement, Volume Buttons: paso 11, imagen 3 de 3
    Herramienta utilizada en este paso:
    • While pushing the volume buttons through their holes in the lower case, remove the buttons and their silicone pads with a pair of tweezers.
    • Work patiently and carefully as the silicone pad is easily torn.
    • Remove the buttons from the silicone pad.
Conclusión
Una persona más ha completado esta guía.
Brett Hartt
Miembro Desde 04/12/10
131,164 Reputación
143 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 123
23,583 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 17
Ultimos 30 días: 70
Todo El Tiempo: 8,052
