Saltar al contenido principal
Nintendo DSi XL Stylus Housing Replacement
Qué necesitas
  1. Nintendo DSi XL Stylus Housing Replacement, Battery: paso 1, imagen 1 de 2 Nintendo DSi XL Stylus Housing Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Nintendo DSi XL Stylus Housing Replacement: paso 2, imagen 1 de 1
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Stylus Housing Replacement, Lower Case: paso 3, imagen 1 de 3 Nintendo DSi XL Stylus Housing Replacement, Lower Case: paso 3, imagen 2 de 3 Nintendo DSi XL Stylus Housing Replacement, Lower Case: paso 3, imagen 3 de 3
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Nintendo DSi XL Stylus Housing Replacement: paso 4, imagen 1 de 1
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Nintendo DSi XL Stylus Housing Replacement: paso 5, imagen 1 de 3 Nintendo DSi XL Stylus Housing Replacement: paso 5, imagen 2 de 3 Nintendo DSi XL Stylus Housing Replacement: paso 5, imagen 3 de 3
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Nintendo DSi XL Stylus Housing Replacement: paso 6, imagen 1 de 2 Nintendo DSi XL Stylus Housing Replacement: paso 6, imagen 2 de 2
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Nintendo DSi XL Stylus Housing Replacement: paso 7, imagen 1 de 2 Nintendo DSi XL Stylus Housing Replacement: paso 7, imagen 2 de 2
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  8. Nintendo DSi XL Stylus Housing Replacement, Right Shoulder Button: paso 8, imagen 1 de 3 Nintendo DSi XL Stylus Housing Replacement, Right Shoulder Button: paso 8, imagen 2 de 3 Nintendo DSi XL Stylus Housing Replacement, Right Shoulder Button: paso 8, imagen 3 de 3
    • Remove the two gold 4.0 mm Phillips screws securing the right shoulder button assembly to the back case.
    • Lift the right shoulder button assembly from the back case.
    • The components of the right shoulder button assembly:
    • Right shoulder button
    • Shoulder button spring
    • Retaining pin
    • Right shoulder button holding panel
  9. Nintendo DSi XL Stylus Housing Replacement, Stylus Housing: paso 9, imagen 1 de 1
    • Remove the stylus from its housing on the right side of the DSi XL.
  10. Nintendo DSi XL Stylus Housing Replacement: paso 10, imagen 1 de 3 Nintendo DSi XL Stylus Housing Replacement: paso 10, imagen 2 de 3 Nintendo DSi XL Stylus Housing Replacement: paso 10, imagen 3 de 3
    • Remove the three 4 mm gold Phillips screws securing the stylus housing to the lower case.
    • Using a spudger, lift the stylus housing off the lower case.
    • Remove the stylus housing from the handheld console.
Conclusión
4 personas más completaron esta guía.
Brett Hartt
Miembro Desde 04/12/10
128,138 Reputación
143 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
141 Miembros
17,893 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 24
Todo El Tiempo: 7,798
