Saltar al contenido principal
Nintendo DSi XL Rear Bezel Replacement
Qué necesitas
  1. Nintendo DSi XL Rear Bezel Replacement, Rear Bezel: paso 1, imagen 1 de 3 Nintendo DSi XL Rear Bezel Replacement, Rear Bezel: paso 1, imagen 2 de 3 Nintendo DSi XL Rear Bezel Replacement, Rear Bezel: paso 1, imagen 3 de 3
    • Use a push pin to remove the four plastic screw covers on the front bezel.
  2. Nintendo DSi XL Rear Bezel Replacement: paso 2, imagen 1 de 1
    • Remove four Phillips screws securing the front bezel to the rear bezel.
  3. Nintendo DSi XL Rear Bezel Replacement: paso 3, imagen 1 de 2 Nintendo DSi XL Rear Bezel Replacement: paso 3, imagen 2 de 2
    • Using two hands, gently slide the rear bezel upwards.
    • The rear bezel will move only about 2 mm.
  4. Nintendo DSi XL Rear Bezel Replacement: paso 4, imagen 1 de 2 Nintendo DSi XL Rear Bezel Replacement: paso 4, imagen 2 de 2
    • Insert a spudger into the gap between the front and rear bezel
    • Rotate the spudger away from the DSi XL, prying the two bezels apart.
  5. Nintendo DSi XL Rear Bezel Replacement: paso 5, imagen 1 de 1
    • In the same manner as described above, continue prying along the top edge of the front and rear bezels.
  6. Nintendo DSi XL Rear Bezel Replacement: paso 6, imagen 1 de 1
    • Separate the rear bezel from the front bezel.
    • Do not attempt to completely remove the rear bezel yet. It is still attached to the front bezel by the rear-facing camera.
  7. Nintendo DSi XL Rear Bezel Replacement: paso 7, imagen 1 de 1
    • Use the flat end of a spudger to pry the rear camera off the rear bezel.
    • Remove the rear bezel.
Conclusión
3 personas más completaron esta guía.
Matthew Newsom
Miembro Desde 01/05/10
39,500 Reputación
67 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 28
Todo El Tiempo: 5,069
