Introducción
Regain power over your DSi XL by replacing or cleaning a faulty or sticky power button.
Qué necesitas
Remove the two Phillips screws securing the battery cover to the back of the handheld console.
Lift the battery cover off the back of the DSi XL.
Remove the four rubber screw covers on the lower case by prying them up with a push pin.
Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-pad/power button cable.
With the pointed end of the spudger, pull the D-pad/power button cable from its connector on the motherboard.
Lift the rubber pad off the back of the power button.
Open the display slightly and push the power button up through the upper case.
Remove the power button from the handheld console.
Una persona más ha completado esta guía.
