Saltar al contenido principal
Introducción
Regain power over your DSi XL by replacing or cleaning a faulty or sticky power button.
  1. Nintendo DSi XL Power Button Replacement, Battery: paso 1, imagen 1 de 2 Nintendo DSi XL Power Button Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Nintendo DSi XL Power Button Replacement: paso 2, imagen 1 de 1
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Power Button Replacement, Lower Case: paso 3, imagen 1 de 3 Nintendo DSi XL Power Button Replacement, Lower Case: paso 3, imagen 2 de 3 Nintendo DSi XL Power Button Replacement, Lower Case: paso 3, imagen 3 de 3
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Nintendo DSi XL Power Button Replacement: paso 4, imagen 1 de 1
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Nintendo DSi XL Power Button Replacement: paso 5, imagen 1 de 3 Nintendo DSi XL Power Button Replacement: paso 5, imagen 2 de 3 Nintendo DSi XL Power Button Replacement: paso 5, imagen 3 de 3
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Nintendo DSi XL Power Button Replacement: paso 6, imagen 1 de 2 Nintendo DSi XL Power Button Replacement: paso 6, imagen 2 de 2
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Nintendo DSi XL Power Button Replacement: paso 7, imagen 1 de 2 Nintendo DSi XL Power Button Replacement: paso 7, imagen 2 de 2
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  8. Nintendo DSi XL Power Button Replacement, Power Board: paso 8, imagen 1 de 2 Nintendo DSi XL Power Button Replacement, Power Board: paso 8, imagen 2 de 2
    • Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-pad/power button cable.
    • With the pointed end of the spudger, pull the D-pad/power button cable from its connector on the motherboard.
  9. Nintendo DSi XL Power Button Replacement: paso 9, imagen 1 de 1
    • Using the flat end of the spudger, carefully pry the battery cable out of its socket on the motherboard.
    • Use caution, as the wires are very fragile and could come out of the connector if pulled on too hard.
  10. Nintendo DSi XL Power Button Replacement: paso 10, imagen 1 de 2 Nintendo DSi XL Power Button Replacement: paso 10, imagen 2 de 2
    • Remove the seven 2.5 mm silver screws securing the power board to the upper case.
    • Lift the power board off the upper case.
  11. Nintendo DSi XL Power Button Replacement, Power Button: paso 11, imagen 1 de 2 Nintendo DSi XL Power Button Replacement, Power Button: paso 11, imagen 2 de 2
    • Lift the rubber pad off the back of the power button.
    • Open the display slightly and push the power button up through the upper case.
    • Remove the power button from the handheld console.
Conclusión
Una persona más ha completado esta guía.
Brett Hartt
Miembro Desde 12/04/10
124,919 Reputación
143 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
147 Miembros
16,036 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 37
Todo El Tiempo: 7,929
